Old 21-01-2008, 07:00 PM   #1 (permalink)
Default SMPS Problem
Hi,
Recently my SMPS has started making a lot of noise, also sometimes my PC freezes or restarts automatically.
Is all this due to the SMPS??
If yes, should I go for repair or a new SMPS??
If new then which one??
Thanks in advance
PS: 500W SMPS will be fine for my PC
purujitb is offline
Old 21-01-2008, 09:02 PM   #2 (permalink)
-----ATi-----
nvidia's Avatar
Default Re: SMPS Problem
Whats your budget for the new SMPS?
If you have a high budget then you can get Cooler master PSUs..
http://twitter.com/akshayms
nvidia is offline
Old 21-01-2008, 09:15 PM   #3 (permalink)
1-3K
purujitb is offline
Old 21-01-2008, 10:42 PM   #4 (permalink)
cooler master 550W - 3.2k
or zebronics pure platinum 500W - 1.8k
but r u sure u've isolated the problem to the smps ?
sagargv is offline
Old 21-01-2008, 10:50 PM   #5 (permalink)
noise is surely from the SMPS...
the computer engineer says it can be repaired...is there a point in repair
PS: it does quites down after few minutes
purujitb is offline
Old 21-01-2008, 11:28 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
Looks like overheating problem.
ravi_9793 is offline
Old 21-01-2008, 11:52 PM   #7 (permalink)
@ravi
any solutions?? or should I just replace it
purujitb is offline
Old 21-01-2008, 11:57 PM   #8 (permalink)
damn busy...
utsav's Avatar
If possible use a frnds psu for some time and then figure out the real problem first
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 22-01-2008, 12:55 PM   #9 (permalink)
-----ATi-----
nvidia's Avatar
If you have an expensive branded PSU then just see if it can be repaired...
If you have a local PSU then get a new one like Cooler Master...
nvidia is offline
SMPS problem setharsh Hardware Q&A 20 30-12-2006 08:13 PM
problem with my smps Naveed Hardware Q&A 4 13-09-2006 08:10 AM
SMPS problem jetboy Hardware Q&A 9 20-05-2006 04:41 PM
problem of smps drsubhadip Hardware Q&A 3 18-01-2006 09:39 PM
Zebronics 500W SMPS. Is it a good SMPS. Advice needed. Yoda QnA (read only) 4 13-11-2004 11:15 PM
