Old 21-01-2008, 10:00 AM   #1 (permalink)
Post pen drive converted to RAW
hi frnds
My UMAX Apus 210 pen drive has been rendered unusable as it has been converted to RAW file system and nothing can be written on it.I cant format it anyway.
Pls help.
mgupta is offline
Old 21-01-2008, 10:24 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: pen drive converted to RAW
People gift free pen-drives at Digit Forums?
Harsh J
www.harshj.com
QwertyManiac is offline
Old 21-01-2008, 03:05 PM   #3 (permalink)
Noobie Pro
alsiladka's Avatar
You cannot format it from the Computer Management console too (Disk Management)?
www.twitter.com/alsiladka
alsiladka is offline
Old 24-01-2008, 02:06 PM   #4 (permalink)
ayush_chh's Avatar
boot in DOS and then try formating........
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
PDF to DOC converted file Charley Software Q&A 4 06-01-2008 08:36 AM
pendrive converted into 3.23 Gb from 1 Gb?? Manshahia Hardware Q&A 7 13-08-2007 03:24 PM
Help!!!!!!!!!! 512 converted to 256 ???? aditya1987 Hardware Q&A 8 13-06-2006 09:21 AM
can .chm file be converted pdf ?????? abhasbajpai Software Q&A 4 02-12-2005 11:58 PM
