Old 20-01-2008, 05:58 PM   #1 (permalink)
Multicore Mutant
Angry Upgraded Bios! Now system won't boot
Mobo is GA-81845GV. Fan and all the led's are running only keyboard is not functioning. I get no beep during startup.
Help. I never upgraded bios before.
Hackattack is offline
Old 20-01-2008, 10:18 PM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: Upgraded Bios! Now system won't boot
try reseting bios by removing bios abttery.
hellgate is offline
Old 20-01-2008, 10:21 PM   #3 (permalink)
Multicore Mutant
I have removed battery, cleared cmos. Still same.
Old 20-01-2008, 10:24 PM   #4 (permalink)
At Hell's Disq
hellgate's Avatar
try a diff psu.cud be a psu prob.also was the bios flashing process interrupted in any way??
hellgate is offline
Old 20-01-2008, 10:25 PM   #5 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
If ur bios update process was interupted in between...then ur mobo is going the dust bin way probably
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 20-01-2008, 10:38 PM   #6 (permalink)
Multicore Mutant
PSU was working fine. After upgrading the flash the system didn't even shutdown by itself it got stuck in the "windows is shutting down" message, then i reset the system. Then it never boot. Only fan and rest lights are glowing, keyboard is not working.
And i upgraded with gigabyte's own utility(@bios) via internet. And it completed successfully without any errors. No interruption in between.
Old 20-01-2008, 11:58 PM   #7 (permalink)
darklord's Avatar
You updated the BIOS in Windows and on top of that you updated through the internet ? Wow man, i must say you have some real guts to try this.
There cant be anything more riskier that what you did.
Best way to flash is in DOS mode. Avoid windows flashing at all costs.
IF you have a bad flsh, you can revive the board by hot flashing. FOr that you need a similar working board.
darklord is offline
Old 21-01-2008, 12:06 AM   #8 (permalink)
ToTheBeatOfUrHeart
Harvik780's Avatar
Well its the manufacturer of the board that's to blame.Why do they provide such stupid utilities which mess up the whole bios.
Well since this is not entirely your fault as the windows bios updating utility was made by the manufacturer of the board you should RMA the board.Or simply put get it replaced.And in future use DOS mode to flash the board.
Harvik780 is offline
Old 21-01-2008, 02:11 AM   #9 (permalink)
Krazy_About_Technology's Avatar
Well, Intel provides Windows based BIOS installers for its Original boards and they never go wrong unless there is a power surge etc. i had upgraded my desktop's BIOS 8 times (an Intel 82865GBF) with Installshield based installer and never got a problem. Its probably the fault of manufacturer.
Anyways, what you could is look for a recovery BIOS on manufacturer's website. I donno about yours but intel does provides recovery BIOS which can be put on a floppy and after resetting a jumper when system reboots, it automatically uses the BIOS floppy to reset the BIOS. Try looking at manufacturer's site. Else you'll have to find out if you have got a socketed BIOS which is not soldered on Mobo. if yes, you can very well replace it, else mobo is gone for good. Even if you are sure that mobo is gone, you can still try Nehru Place if you are in Delhi. There some guys can perform many unofficial fixes to hardware and i'm sure they'll find a soln for you. Good luck Dude!
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
Krazy_About_Technology is offline
Old 21-01-2008, 02:34 AM   #10 (permalink)
At Hell's Disq
hellgate's Avatar
Originally Posted by Krazy_About_Technology View Post
i had upgraded my desktop's BIOS 8 times (an Intel 82865GBF) with Installshield based installer and never got a problem.!
ur a lucky guy then.
windows based bios flashers r the worst of the lot.if theres a prob with ur os and the system hangs in between the bios flashing process then ur screwed for good.
hellgate is offline
Old 21-01-2008, 03:08 AM   #11 (permalink)
Yup, may be i am I just took some care and stopped all major services and background programs that do not have anything to do with the install. Then on this clean system, i upgraded my BIOS.
Old 21-01-2008, 08:13 AM   #12 (permalink)
PhotonAttack
DigitalDude's Avatar
there is nothing wrong in flashing bios in windows I have done it a few times with the Dell utility for that.... this is not a problem for modern motherboards...
a few asus mobos can even survive if the process is stopped abruptly in the middle...
sometimes the system wont boot if the mobo cell is dead... try changing the mobo cell
DigitalDude is online now
Old 21-01-2008, 10:45 AM   #13 (permalink)
Multicore Mutant
I think my board is gone.
@darklord I have a friend who have a similar board, but i think it cannot be hot flashed cos the bios chip is soldered on my mobo.
I couldn't find any recovery bios option in their website.
Only thing i can try i replace with a new battery.
Any more suggestions.
Old 21-01-2008, 11:56 AM   #14 (permalink)
Multicore Mutant
Totally agree. They should be sued for making such stupid utilities which give us such nightmares. And also there is no recovery option or such thing, one small mistake of theirs ruins the whole mobo, and now who is going to pay for that, nice way to make money idiot gigabyte.
Even replaced with a new battery, no use.
Old 21-01-2008, 05:08 PM   #15 (permalink)
Try consulting a local vendor....though chances are rare that they wil find any solution.....just give it a try
Sony Vaio CW26FG
Old 22-01-2008, 12:00 AM   #16 (permalink)
darklord's Avatar
Give it for repairs at the service centre.They will reflash and give it to you.
darklord is offline
Old 22-01-2008, 12:08 AM   #17 (permalink)
damn busy...
utsav's Avatar
In my biostar mobo there is a bios boot block function which helps if anything goes wrong while updating bios but cant say abt gigabyte
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 12-02-2008, 04:32 AM   #18 (permalink)
I had the same problem after updating BIOS of my GIGABYTE 8I845 mobo 3 weeks ago. I took it to Gigabyte service centre twice. They repaired my mobo for ONLY Rs. 1000 but it worked for few hours and started giving me same problem then I took it to service centre again and asked for repair without any charges, and again they repaired it. On 11 Feb. 2008 I got my machine back to work after long wait of 3 weeks At first they changed the BIOS chip and for second time they just cleaned the channels where we put RAM. So one thing u can do at first is to clean those channels by urself
jamsus is offline
Old 12-02-2008, 09:39 AM   #19 (permalink)
does ur floppy drive keep trying to read something ? if yes , maybe there is hope. if not , u'll HAVE to rma it.
sagargv is offline
boot/bios screen filled with characters realdan Hardware Q&A 2 04-12-2007 08:47 PM
BIOS boot up problem vinodxx Software Q&A 4 03-08-2007 02:23 PM
boot problem with BIOS demoninside9 Hardware Q&A 7 22-07-2007 07:36 AM
System cannot find system disk during boot. sushantasarkar Hardware Q&A 1 04-02-2007 10:05 PM
NEED HELP!! pc WON'T boot, No bios access, SIREN like noise rage_666 Hardware Q&A 8 27-01-2006 03:48 PM
