Old 18-01-2008, 03:47 PM   #1 (permalink)
Norms Buster
Exclamation Should I disconnect USB devices before restart/shutdown ?
  1. Is there any need to disconnect all the USB devices before restart/shutdown ?
  2. Is there any need to disconnect USB device like a modem that we use often ?
  3. If I didn't disconnect, will there be any chances of hardware failure ?
  4. I'm hearing a beep during POST(Power-On-Self-Test) when I had kept connected my USB modem. What does that signify ?
Please help...
VexByte is offline
Old 18-01-2008, 04:35 PM   #2 (permalink)
Married!
Rahim's Avatar
Default Re: Should I disconnect USB devices before restart/shutdown ?
There is no need for disconnecting USB devices and its quite normal to hear the "beep" sound when booting up.
|| GNU/Linux User || PCLOS KDE 4.6 || 17" DELL Studio ||
topdocumentaryfilms.com
Rahim is offline
Old 18-01-2008, 04:38 PM   #3 (permalink)
Think Zen.
ray|raven's Avatar
Its not a problem to have usb devices connected.
Just make sure that your system doesn't have usb boot as a priority,
SSD's have a limited read/write cycle and you don't want to waste it with boot checks.
Regards,
ray
Do what you will; but not because you must. -- Zen Quote
ray|raven is offline
Old 18-01-2008, 06:18 PM   #4 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Somehow I face a problem when I leave my USB stick(actually an mp3 player) in the port and try to restart. The system hangs right at the BIOS.
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 19-01-2008, 07:44 AM   #5 (permalink)
Norms Buster
If there is no problem, then what does the beep signify ?
VexByte is offline
Shutdown = Restart ??????? codename_romeo Software Q&A 14 20-12-2007 06:17 PM
Shutdown instead of Restart lahratla QnA (read only) 4 23-10-2005 12:02 AM
Shutdown ur pc to restart it !!!!!!! abhi1234 QnA (read only) 5 30-04-2005 07:44 PM
Fast restart & shutdown Neil QnA (read only) 4 30-12-2004 12:05 AM
shutdown = restart simplegeek QnA (read only) 1 28-11-2004 07:11 PM
