Hi guys,
I have an external tv tuner card(Tech-Com Make),
it connects directly to the Monitor.
I need to know how to connect it via the CPU , so i can alternate between the CPU and TV at ease.
Thanx,
ray
Do what you will; but not because you must. -- Zen Quote
Re: How to use an External TV Tuner along with CPU?
my frnd also has the same
their must be 1 Cable(wire) with it
1st
one end of wire connect to CPU and other to TV Tuner than
2nd
Monitors Serial Cable connect to TV tuner
When u switch On TV Tuner Card
TV will display on Monitor
and when u switch off it will become PC again
also u dont need to On the PC for watching TV
and also u can do
on the PC
make something working like - download anything or make a Virus scan
and
on the TV tuner
TV will start on Monitor and you PC will do its work in Background
! जय हिंद ! Proud to be INDIAN
Reason: Automerged Doublepost
