Old 17-01-2008, 08:24 AM   #1 (permalink)
New
New's Avatar
Default Two pen drives gone within 5 minutes!
I went to my friend room yesterday to bring some songs and other things as he has air tel broadband...When i connect my Transcend 1 GB pen drive it did't work....Within a minute it was so hot that I could't hold it...After that he inserted one of his two pen drives and that one was also not working.After that it was the turn to insert Transcend 2GB pen drive and for our luck it worked well.When we check two pen drives in my system and two more other system we came to know that both of them have gone to hell.
Now I would like know what could be the problem behind this tragedy as I had lost one 160GB HDD in the same system..
New is offline
Old 17-01-2008, 08:30 AM   #2 (permalink)
Still Shining!
Lucky_star's Avatar
Default Re: Two pen drives gone within 5 minutes!
Is that system properly earthed??
Improper earthing will sometimes burn out components like this.
Nokia N86 8MP
Lucky_star is offline
Old 17-01-2008, 08:39 AM   #3 (permalink)
New
New's Avatar
Don't know about that...But his 2GB pen drive is working fine..We have lost two pen drives of 1Gb(Transcend)
New is offline
Old 17-01-2008, 12:10 PM   #4 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
it has to be bad power supply to the USB port and probably leaking current is reaching there thru the ground pins which is common for the whole system. sadly there is no simple way to check this but to verify that you have proper earthing for ur SMPS and closely check the cabinate from inside for loose screws and twisted wires.
Rollercoaster is offline
Old 17-01-2008, 02:22 PM   #5 (permalink)
666
solomon_paulraj's Avatar
Originally Posted by New View Post
After that he inserted one of his two pen drives and that one was also not working.........
my friend system is also having the same problem.. the system is very clean.. so no pins or twisted wire.
i want to confirm, whether bad earthing will cause the problem..
we have lost 2x1 gb transcend pen drive and 2x1 usb game pads..
MSI-P35-NEO| C2D-E7300 | XV-9600GT | WD-640 | LEADTEK-DTV-1800H | CORSAIR-TWIN2X2048-6400C4DHX | ZEBRONICS-PRO M500W | SONY-DRU-V200S | LOGITECH-X90 CORDLESS
solomon_paulraj is offline
Old 17-01-2008, 02:30 PM   #6 (permalink)
Alive Again...
satyamy's Avatar
Their is Some Power Problem
either in internal Connection or with Main Power Earthing
! जय हिंद ! Proud to be INDIAN
satyamy is offline
Old 17-01-2008, 02:41 PM   #7 (permalink)
New
New's Avatar
I agree that there is a power problem...But his system is working fine...He is using his 2Gb pen drive without any problem...Why it has happened to 1Gb pen drive only?
New is offline
Old 17-01-2008, 03:49 PM   #8 (permalink)
well it must be a older model and not able to handle bad power.
i recommend u get a multimeter and a electronics buff near you to give ur pc a checkup.
Old 17-01-2008, 05:42 PM   #9 (permalink)
New
New's Avatar
Thanks friend.I will do that..
New is offline
Old 17-01-2008, 05:51 PM   #10 (permalink)
-----ATi-----
nvidia's Avatar
OMG!!!
http://twitter.com/akshayms
nvidia is offline
Old 17-01-2008, 06:07 PM   #11 (permalink)
New
New's Avatar
^What happened?
New is offline
Old 17-01-2008, 09:05 PM   #12 (permalink)
-----ATi-----
nvidia's Avatar
^^2 pen drives burnt within 5 mins.. Got a li'l surprised thats all
nvidia is offline
Old 17-01-2008, 09:16 PM   #13 (permalink)
lol
gone with 60 seconds
Faun is online now
Old 17-01-2008, 09:26 PM   #14 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
It has to be earthing problem or power surge in the usb....... check for earthing problems first
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 17-01-2008, 09:33 PM   #15 (permalink)
Elevating Humanity
The Conqueror's Avatar
OMG!
I have never ever heard of this kind of problem!
Regards,
The Conqueror
The Conqueror is offline
Old 17-01-2008, 10:00 PM   #16 (permalink)
smile's Avatar
Cool Re: Two pen drives gone within 5 minutes!
USB drive was sooo hot that u cant hold it..........I really cant understand ............why it will becpme so hot
SR
smile is offline
Old 17-01-2008, 10:11 PM   #17 (permalink)
New
New's Avatar
I do agree that all happened because of power problem...My question is how come that 2GB pendrive working fine?All of the pen drives are of the same brand....
@smile
did't you get that?
New is offline
Old 17-01-2008, 11:39 PM   #18 (permalink)
Still Shining!
Lucky_star's Avatar
Your 2 GB pendrive is destined to live, while others were not so lucky...
Nokia N86 8MP
Old 19-01-2008, 02:17 PM   #19 (permalink)
New
New's Avatar
New is offline
Old 19-01-2008, 02:59 PM   #20 (permalink)
damn busy...
utsav's Avatar
Its due to overvoltage i think which was unbearable by the 1GB drives but the 2GB drive is able to bear it
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 19-01-2008, 03:11 PM   #21 (permalink)
New
New's Avatar
I do think so...Bcoz when I tried to connect his 2Gb pen drive to my system through USB extension cable xp couldn't detect it..But, when i connect it to the USB slot it worked fine..I asked that vendor for the replacement and he told he has to send it to the company...I hope I will get replacement.
New is offline
Old 19-01-2008, 05:34 PM   #22 (permalink)
-----ATi-----
nvidia's Avatar
Originally Posted by T159 View Post
lol
Its 300seconds....
nvidia is offline
Old 19-01-2008, 11:23 PM   #23 (permalink)
New
New's Avatar
Seems pretty bad in maths
New is offline
Noise for 3 minutes!!!!!!!! Help!!!!!!!! The Unknown Hardware Q&A 2 04-07-2007 02:11 AM
restore pc in 10 minutes Ramakrishnan Tutorials 13 06-05-2006 07:57 PM
Digit's DVD drives the market's drives shakshy QnA (read only) 3 30-10-2004 09:27 PM
