Old 15-01-2008, 07:31 PM   #1 (permalink)
Ranjya's Avatar
Default External HDD For booting
I have a i810e + P3 + 256mb + 20GB.
The 20GB HDD is going south.
I can buy a PATA HDD but that will be not such a good idea.
Can I buy a SATA hdd put it into a enclosure and boot from it.
That would be a good buy for future.
I could not find option in BIOS for USB booting.
Ranjya is offline
Old 15-01-2008, 07:34 PM   #2 (permalink)
At Hell's Disq
hellgate's Avatar
Default Re: External HDD For booting
u can always buy a pci SATA expansion card for 500 bucks approx.in this way u'll be saved the hassle of making an xternal hdd.
hellgate is offline
Old 15-01-2008, 08:04 PM   #3 (permalink)
Ranjya's Avatar
I cannot......
PCI 1) GeForce FX5200
2) D-link lan card......dataone
3) USB2.0 PCI card
I guess have to throw away pc and buy new.
There is a adapter for SATA HDD --->IDE slot.
Costs 750/- here in Pune.
But If the SATA does not have a molex power supply
what do I do.
Ranjya is offline
Old 15-01-2008, 08:17 PM   #4 (permalink)
At Hell's Disq
hellgate's Avatar
get a 4-pin molex to SATA pwr converter when u buy the mobo.it sud solve ur probs.
hellgate is offline
Old 16-01-2008, 06:33 PM   #5 (permalink)
Ranjya's Avatar
Thanks.
Is this available ?
That could solve my problem.
A bit expensive though.
I can boot with present HDD only in safe mode.
After I have rebooted 4-5 times one of my 3 OS boots normally.
I think it is HDD related.
Ranjya is offline
Old 16-01-2008, 06:53 PM   #6 (permalink)
At Hell's Disq
hellgate's Avatar
u can get the pwr converter for free when u buy the SATA hdd.else u can buy it separately for 10 bucks.
connect one end of this converter to the 4-pin molex connector of psu and the other end to the SATA hdd.
hellgate is offline
Old 16-01-2008, 07:38 PM   #7 (permalink)
Ranjya's Avatar
Are you sure about the 10bucks.
I was checking ebay it is for 54bucks.
Anyway that doesn't bother me.
It is the price of SATA to IDE converter....750/-
That is steep.
I mean Seagate barracuda 7200.10 160gb for 2200/- + 750/- + 54/-(or 10/-)
approx 3000/-
The 750/- is what hurts.
Still you cannot have your cake and eat it too.
Thanks for your help.
Ranjya is offline
Old 17-01-2008, 06:03 AM   #8 (permalink)
d
given your situation.. the PATA option is best.. since you don't seem to think that's a very good idea(why?!?!) the next best would be USB.
if you go with a PCI sata card, you will have to install drivers for the card in windows setup from a floppy diskette.. its a hassle.
The torquemaster rules.
d is offline
booting hariharan Software Q&A 6 11-12-2006 07:37 PM
booting from external hard disk desijays Hardware Q&A 3 25-11-2006 08:58 AM
PC Not Booting homiyar Software Q&A 5 15-07-2006 08:04 PM
pc booting again n again gycapri Software Q&A 10 11-03-2006 09:09 AM
Installing windows and booting from external USB HDD sids Software Q&A 1 21-02-2006 05:03 PM
