Old 13-01-2008, 07:05 PM   #1 (permalink)
Default Hard Disk Woes
I recently attached my old IDE HARD DISK to my existing configuration BUT I HAVE NOTICED THAT THERE IS NO PLACE IN MY CABINET . SO CAN I PLACE IT VERTICALLY INSIDE MY CABINET? WILL IT HAVE ANY ADVERSE EFFECTS ON ITS PERFORMANCE OR LIFE? THANKS IN ADVANCE.
nakulp is offline
Old 14-01-2008, 01:40 PM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: Hard Disk Woes
I think you can place it vertically & use it without any issue.
But I'll recomend you to buy a 3.5 inch hdd external casing and use your hard disk as a external one.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 14-01-2008, 05:41 PM   #3 (permalink)
Thanks. But how can i get the ide cable outside?
nakulp is offline
Old 14-01-2008, 05:44 PM   #4 (permalink)
-----ATi-----
nvidia's Avatar
It will not have any impact on the performance AFAIK.
http://twitter.com/akshayms
nvidia is offline
Old 14-01-2008, 05:45 PM   #5 (permalink)
TechTin.com
ravi_9793's Avatar
you can use it in any position..but it must be fixed properly.Means it should be fixed tightly with screws.
ravi_9793 is offline
Old 15-01-2008, 12:51 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
instead y not use an external casing ..... its cheap 2 .......
... W H O T ...
ax3 is offline
Old 16-01-2008, 07:13 PM   #7 (permalink)
Fast 'N' Furious
topgear's Avatar
@ nakulp
try these links :
350gb hdd on P3 ! ! !
http://www.chotocheeta.com/2007/10/2...usb-hard-disk/
topgear is offline
Old 17-01-2008, 06:04 AM   #8 (permalink)
d
you can place it vertically no problem. just make sure it doesn't move around during normal operation.. my hard disk's running that way too. won't affect perfomance in any way
The torquemaster rules.
d is offline
all files from IDE hard disk with windows 2000 to SATA II hard disk with windows jagadish2005 Software Q&A 8 10-04-2007 11:08 AM
Hard disk to buy ? sbhas2k Hardware Q&A 4 10-12-2006 12:40 PM
Seagate 160gb Hard Drive installation woes sysfilez Hardware Q&A 4 26-09-2006 11:12 AM
compaq deskpro ep/sb series not detecting hard disk disk aditya169 QnA (read only) 3 22-05-2005 07:14 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
