Old 13-01-2008, 03:57 AM   #1 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Arrow Buying some new hardware(UPS and subwoofer): need suggestions
Hello guys,
I am planning to buy the following:
1. UPS or battery
2. Speakers and subwoofer
The UPS story:
My UPS is not able to give backup. As soon as voltage fluctuates or power goes off, it goes into the backup mode but PC switches off. I have this problem for almost an year after an accident. That day, I switched on the UPS and after sometime, I could literally hear 'blasts' from UPS. They lasted for about 15 - 30 secs during which I was in another room. I could see even red flashes over walls of the room in which PC and UPS are there. I somehow managed to switch off the UPS with a long wooden stick. I could smell of plastic/rubber being burnt after I switched off and the room was full of smoke.
After about 5 hrs, I dared to switch on the UPS and it again worked like normal, except that it could not give backup.
So where do you guys think is the problem? Do I need to replace the whole UPS unit or do I need to replace the batteries alone?
(offtopic: It was good luck that I wasn't in the room. usually after starting the PC, I sit in front of it while it boots, but that day, I went to another room while the PC was booting!)
The speaker story:
I had those typical cheap small speakers which I got when I bouught the assembled PC. Around a month back, when I started the PC, suddenly there was some 'Dhub' sound from the speakers and they would not work. These speakers were not connected through the UPS but were directly connected to the plug.
Now I want to buy speakers but I prefer to buy subwoofers so that I can enjoy bass on my PC itself.
Waitings for your inputs!
Thank you for your time.
-Rohan
गीक होना माँगता
victor_rambo is offline
Old 13-01-2008, 04:26 AM   #2 (permalink)
left this forum longback
praka123's Avatar
Default Re: Buying some new hardware(UPS and subwoofer): need suggestions
cheap quality ups/stabilizers face this problem when voltage fluctuation or over voltage comes!i have my step-up burnt once and got repaired
my advice is,to get proper earthing,get a apc/some good brand UPS!
praka123 is offline
Old 13-01-2008, 06:24 PM   #3 (permalink)
हॉर्न ओके प्लीज़
ok! Thanks
APC for UPS!
गीक होना माँगता
Wi-Fi Hardware Suggestions iMav QnA (read only) 29 30-09-2007 12:21 PM
suggestions for buying mp3 player?? Caesar Software Q&A 13 08-09-2007 06:48 PM
Buying a mobile.?? .Get SUGGESTIONS here..!! akshaykapoor_3 Buying Advice 7 17-05-2007 08:27 AM
Need ur Suggestions 4 Hardware khandu QnA (read only) 11 03-05-2005 06:48 PM
