Old 12-01-2008, 02:49 PM   #1 (permalink)
Default intel 946gzis
i have intel 946gzis board. the sound driver provided with my board cd is of sigmatel audio driver. In XP, it works fine but in vista, when i install the driver software, the sound gets distorted.Without the driver software, i am not able to use microphone and the front jacks which work fine in XP. Where can i get the driver software?
Also, Does the board's graphics contain some error? because some game which run in other board(with lower configuration)with default graphics(ati radon's) dont work with my board. Is this due to some other error or do i need to update the driver or a new graphix card should be purchased(which i dont want to do now). Is there any way?
saubrl is offline
Old 15-01-2008, 12:00 AM   #2 (permalink)
Default Re: intel 946gzis
i too have an intel 946gzis mobo based system (with e6300). i do not have ne graphics card. the problem is certain games do not run smoothly on my comp (e.g. igi2 etc) which run quite smoothly on my frnds comp which has 945 series mobo (e4300) without ne g card. what can be the problem???
slyfox is offline
Old 15-01-2008, 11:39 AM   #3 (permalink)
moshel's Avatar
@saubrl....the only suggestion that comes to mind for ur graphics problem is to update the drivers...
@slyfox....update ur video drivers and mobo drivers....also check which version of Directx ur having and upgrade to 9.0c in XP.
moshel is offline
Old 16-01-2008, 09:40 PM   #4 (permalink)
As far as i know, i have the latest driver which i downloaded from intel's website. And my real problem is not with graphics but with sound
saubrl is offline
Old 17-01-2008, 05:08 PM   #5 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
^^I got the exact same mobo.
1.Sounds workd out of box on vista for me,no need to install drivers.
2.I have vista drivers for singmatel audio(The mobo's onboard audio controller),which works just fine here.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
Intel core duo t2450 @2 Ghz or intel dual core @ 1.73Ghz ??????????? arunks CPU / Motherboards 6 04-03-2008 11:54 PM
AMD SELLS INTEL CPUs... HAS IT COMPLETELY LOST THE WAR WITH INTEL C2D vish786 Technology News 9 09-06-2007 07:46 AM
Intel mobo for Intel Core 2 Duo E6300 !! kaps_2222 Hardware Q&A 3 21-04-2007 10:32 AM
Which is best.--->Intel 915P or Intel 915G vps85 CPU / Motherboards 5 20-01-2005 08:57 PM
