Old 12-01-2008, 01:27 PM   #1 (permalink)
The Thread Killer >:)
phreak0ut's Avatar
Question Where do I get isopropyl alcohol?
Need to clean the CPU and HS and apply AS5(will be buying). Where will i get it? Approx price?
Want to make this world a better place? Then, start seeding and don't be just a leecher :)
phreak0ut is offline
Old 12-01-2008, 01:31 PM   #2 (permalink)
Default Re: Where do I get isopropyl alcohol?
Use the pure Laboratory grade version.
You can find it at any laboratory chemical supply house. It comes in 500 ml bottles and costs about Rs. 200.
pillainp is offline
Old 12-01-2008, 02:33 PM   #3 (permalink)
phreak0ut's Avatar
What will I do with 500ml?? Anyway, can I get it just like that? Won't they question me, if I buy chemicals?
Old 12-01-2008, 05:02 PM   #4 (permalink)
dOm1naTOr's Avatar
Get a small bottle of surgical spirit. It is 99% pure methale alcohol nd it too can be used to clean off the thermal paste. It ll be some 20~30 bucks.
The property of instant vapourization is used in the purpose. So Methanol is as gud as the isopropyl alcohol.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 12-01-2008, 05:48 PM   #5 (permalink)
=--=l33t=--=
ring_wraith's Avatar
nice to see some people care about Thermal paste.
to be honest, the reason you are suggested to use isopropyl alcohol is just because it evaporates lightning fast. Even white petrol should serve your purpose.
ring_wraith is offline
Old 12-01-2008, 06:20 PM   #6 (permalink)
dOm1naTOr's Avatar
Petrol cud even earse the letters on proccy though it doesn't affect its performance or inner circuits.
Don't rub with any metal objects which cud cause scratch nd wud cause reduced surface contact with heatsink surface.
Ive myself used surgical spirits for this purpose several times. But dun use concentrated methanol for cleaning CDs, which causes the plastic to melt slightly nd the surface becomes vague.
G3: XPS M1530 |
FZ 16.
Old 12-01-2008, 06:37 PM   #7 (permalink)
Google Bot
Pathik's Avatar
Get any alcoholish substance. Doesnt need to be pure. I think even acetone should work.
Pathik is offline
Old 12-01-2008, 06:54 PM   #8 (permalink)
dOm1naTOr's Avatar
@Pathik
acetone is too strong na? It cud even melt hard plastics,rubber,paints etc. So its dangerous if a lil of it flows to edged and fets into socket.
Havn't tried it coz surgical alcohol was easily avaialble for sub 20/- in 50ml or 100ml bottles from medical stores. And acetone is way more expensive and no other use.
And lastly dun drink the remaining spirit as it cud blind u. Only dilute ethanol is edible.
G3: XPS M1530 |
FZ 16.
Old 12-01-2008, 07:05 PM   #9 (permalink)
Google Bot
Pathik's Avatar
Yep i haven't tried it but i dont think it is that strong. But i think it should do the job if used carefully.
haha yea..
Pathik is offline
Old 12-01-2008, 08:00 PM   #10 (permalink)
phreak0ut's Avatar
Actually I was thinking if vodka would work out That seems to be easier for me to get. Thanks to few friends of mine I don't booze though I'll probably use surgical spirit then
Old 12-01-2008, 08:07 PM   #11 (permalink)
Google Bot
Pathik's Avatar
No need to justify man.
Tu agar bewda hota to bhi we wd have helped you. lmao
Pathik is offline
Old 12-01-2008, 08:10 PM   #12 (permalink)
phreak0ut's Avatar
Thanks Pathik
Old 12-01-2008, 10:32 PM   #13 (permalink)
It is generally recommended to use "pure" IPA since it will not leave any residue and evaporates fast. In case of hard to remove situations, acetone is also suggested (to be used carefully so that it touches nowhere else) followed by IPA and a lint free cloth. Any residue, dirt or lint will affect the surface contact and thereby thermal conduction.
I do buy from Lab suppliers.
V.Prem Kumar
janitha is offline
Old 13-01-2008, 10:10 AM   #14 (permalink)
phreak0ut's Avatar
@Janitha-Thanks for the suggestion. Apart from cleaning CPU, on what other components can this be used for cleaning?
Old 13-01-2008, 11:07 AM   #15 (permalink)
Almost anything other than LCD screen!
V.Prem Kumar
janitha is offline
Alcohol Help needed AMITAGARWAL02 Software Q&A 5 14-09-2007 02:15 AM
alcohol jmit QnA (read only) 6 18-05-2006 12:35 PM
Help with Alcohol 120% needed??? go4saket QnA (read only) 8 11-04-2006 08:44 PM
alcohol 120% problem legolas QnA (read only) 12 19-10-2005 07:28 PM
alcohol 120% or virtual cd cybermanas QnA (read only) 21 18-09-2005 03:42 PM
