Originally Posted by nitinm
 my pc config is 845 motherboard,2.4 ghz 256 ram, i am unable to install
windows xp again, when i boot the machine from boot option after few minutes pc shuts down, even when i try to use the last known good config
the pc does'nt do anything, i have even changed my optical drive and the cd
but no solution....
i dont get any error message it directly shuts down, i have checked with my
fans they are running properly, first i was trying to reinstall xp by upgrade option but while creating the config of machine the sytem hanged after that
now while i start up the machine i get two options first is start winxp pro edition, and the other is startsetup of xp, when is go for the first option the pc says pc config file is not set and asks me for the repair option but nothing happens, the other option i.e the setup when i run it the pc power goes off!
