Old 10-01-2008, 07:04 PM   #1 (permalink)
Tired of being sorry!
quad_master's Avatar
Question Need help to buy a TFT monitor!! Plz...
I want to buy a 17" TFT monitor. My budget is 8-10K.
I'm a mid-level gamer. So, mainly I will use it to playing games.
My concerns are-:
I. Should I go for a wide screen TFT or not???
II. A good contrast ratio, brightness, and at least 160 wider angel.
III. I think for gaming, the lower the response time the better.
IV. And of course the "Dead Pixel" issues.
V. If there is a DVI port - I don't mind!!!
So which is The Best TFT to get?
Plzzzzzzzz suggest!
There are 10 types of people in this world, those who understand binary and those who do not.
quad_master is offline
Old 10-01-2008, 07:22 PM   #2 (permalink)
Learner
Kniwor's Avatar
Default Re: Need help to buy a TFT monitor!! Plz...
wide-screens are in fashion these days, but I would suggest getting a normal screen if you don't watch a lot of movies, normal screens have more viewable area, are better for gaming. A normal screen would be a bit costlier than a wide screen of the same size. Though you have to realize that a normal screen of same diagonal length is actually bigger area-wise than a wide screen, and also has higher resolution. So the elevated cost makes sense.
Kniwor is offline
Old 10-01-2008, 07:41 PM   #3 (permalink)
Wire muncher!
infra_red_dude's Avatar
My concerns are-:
Plzzzzzzzz suggest!
1) Do the games you play support native wide-screen resolutions?
2) Do you also watch too many movies in widescreen format (most of them are in this format anyway)
3) Can your current gfx card handle wide-screen resolutions or do you hafta buy a new gfx card?
If you answer these questions you can yourself find the answer as to whether you'd want a wide-screen or not.
Also whatever you buy look for a contrast ratio of at least 1000:1. Dead Pixel issues are kinda overhyped. At least using a laptop (again, its the same LCD), I haf not exp. even on dead pixel after using it for a period of 3.5 years.
Secondly, I saw Dell LCDs are quite cheap these dayz and also don't compromise on quality. You may wanna haf a look at them.
infra_red_dude is offline
Old 10-01-2008, 11:59 PM   #4 (permalink)
Thank u guyz!!
Actually I'm little bit confused in this matter. There are so many reputed brands in the electronics media market. So I want you to help me in this matter.
However thanks again!
Old 11-01-2008, 12:26 AM   #5 (permalink)
Rockstar11's Avatar
dont buy Super flop View Sonic vx1932wm
http://www.chotocheeta.com/2007/10/0...onic-vx1932wm/
Rockstar11 is offline
There is a ghost in my monitor!!!Monitor going crazy!!!!!!need help..... tango_cash Hardware Q&A 1 13-12-2007 12:03 PM
TFT Monitor nach p Hardware Q&A 6 02-03-2007 10:34 PM
ps2 on the monitor?? deepinder_mann1988 Gamerz 2 16-06-2006 08:34 PM
Monitor and Monitor Power Light is blinking aathif QnA (read only) 4 21-05-2005 05:20 PM
TV as a MONITOR. deepinder_mann1988 QnA (read only) 6 21-10-2004 11:31 PM
