Old 10-01-2008, 02:23 PM   #1 (permalink)
Default Problem writing DVD -R
Hi
I have a sony DVD writer which I bought 6 months back,
And the problem is when ever I'm trying to write data in DvD's labeled DVD -R The drive is writing 1-3 % and after that it is showing a Error message cannot Write the Data, I've tried using various DVD brands but the result is same.
I've also tried changing the nero software installed various versions of nero.
Help me out!!
Uday
uday56 is offline
Old 10-01-2008, 02:37 PM   #2 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Default Re: Problem writing DVD -R
Seems like its time to utilize its warranty.
But before that clean the lens of the drive and check the connections to the drive!
keith_j_snyder2 is offline
Old 10-01-2008, 02:43 PM   #3 (permalink)
Boy Waiting To Be A Man!!
kayos's Avatar
pls also chek u r using the correct options ... as once it happened with me that in drop down menu on selecting device with which to burn i had my cd burner burning dvd... lol i know its foolish but it may happen and all the time i kept blaming that my dvd burner only burnt CDs... lol
With No Power Comes No Responsibility !!!
-Clark I
kayos is offline
Old 13-01-2008, 04:20 PM   #4 (permalink)
Don't I have any other option instead of replacing
Uday
uday56 is offline
Old 13-01-2008, 04:31 PM   #5 (permalink)
napster007's Avatar
try using the lense cleaner as kyos has said. if it still gives a problem. then there's no option
napster007 is offline
Help :DVD Writing problem kg_87 Software Q&A 5 29-06-2007 11:13 PM
Problem in writing DVD gau_pppu Software Q&A 8 09-04-2007 10:34 AM
DVD writing problem..... Ambar Hardware Q&A 7 05-04-2007 09:00 AM
Problem writing DVD zegulas QnA (read only) 7 12-09-2006 11:34 AM
DVD Writing problem !! hittheswitch QnA (read only) 1 16-08-2005 06:14 AM
