Old 10-01-2008, 12:38 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default 350gb hdd on P3 ! ! !
will my 350gb hdd b recognized on my frds p3 machine ?
... W H O T ...
ax3 is offline
Old 10-01-2008, 12:54 PM   #2 (permalink)
Default Re: 350gb hdd on P3 ! ! !
I think you are referring to a PATA/IDE 320 GB HDD.
It will most surely work.
Also, if ur friend is using Win2k or WinXP or greater OS, it is sure to work.
But if its a SATA HDD, it won't work. You would need a PCI to SATA adapter or HDD enclosure (thru USB) for making it work.
shadow2get is offline
Old 10-01-2008, 01:05 PM   #3 (permalink)
ax3
ax3's Avatar
thanx 4 reply ......
he has xp loaded .....
... W H O T ...
ax3 is offline
Old 10-01-2008, 06:27 PM   #4 (permalink)
I have a p3 with an intel 815 motherboard. It only recognises a max of 120gb hdd. same with intel 810 motherboard.
casual_gamer is offline
Old 11-01-2008, 05:16 PM   #5 (permalink)
ax3
ax3's Avatar
bt did ya check through usb port also ?
... W H O T ...
ax3 is offline
Old 12-01-2008, 11:46 AM   #6 (permalink)
Actually i have a 160gb disk as slave, i was using only 120gb till now. But today through the windows disk management, i have formatted the remaining 30gb and windows recognises! But you need to install Intel Application Accelerator.
So i guess, 350gb should not be a problem.
I had first formatted the 160gb from dos, so the whole 160gb was not detected. But windows will recognize your whole disk, just don't forget to install IAA.
Old 12-01-2008, 11:53 AM   #7 (permalink)
Rebooting
Choto Cheeta's Avatar
Personal Suggestion use a USB 3.5" Casing with lowerd end system which needs higher storage needs...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 12-01-2008, 12:17 PM   #8 (permalink)
Stay Silent!
enticer86's Avatar
^^That seems to be a nice thing to use.. thanx for sharing.
I saw me running,
'Twas a long, long run.
But the view was so stunning,
And that made it so much fun... ©
enticer86 is offline
Old 12-01-2008, 04:51 PM   #9 (permalink)
Fast 'N' Furious
topgear's Avatar
Cool Re: 350gb hdd on P3 ! ! !
+ 1 for that ! ! !
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 14-01-2008, 12:33 PM   #10 (permalink)
ax3
ax3's Avatar
yes u r right @Choto Cheeta ........ i already have external usb connector & thanx 2 ur site\blog just inspired 2 "GO GET IT" kinda attitude .......
thanx ......
will b doing transfering job this weekend ...... hope it goes smoothly .....
... W H O T ...
ax3 is offline
Old 14-01-2008, 02:23 PM   #11 (permalink)
Google Bot
Pathik's Avatar
You can do that or get a Seagate Free Agent disk.
http://www.seagate.com/www/en-us/pro...p_data_movers/
Pathik is offline
