Old 09-01-2008, 09:33 PM   #1 (permalink)
Optimus Prime's Avatar
Default probs upgradin ma RAM..!!!!
I have 2 chips of 128MB DDR333/266 PC2700 UNBUFF NON ECC and 80GB ATA/100 IDE HDD 7200rpm.Also is AMD athlon 2000+,266MHz on a gigabyte 7VM333M-RZ HI CASPIAN motherboard.One is my PC has becum very slow.Wat shud i do 2 make it fast besides upgradin my RAM to 1GB. Also plz tell whether I shud have 2 chips of 1GB or just 1.Two, i want to buy a gud TV tuner card, DVD-RW dat can make labels n supports al formats n also one graphic card below 8K.I have 1 4X AGP slot n 3 PCI slots.I also need help regarding the few things i shud consider before buyin these things for eg. slots n stuff.plz advise.
Optimus Prime is offline
Old 09-01-2008, 09:49 PM   #2 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
Default Re: probs upgradin ma RAM..!!!!
Hmmm though i am not answering exactly to ur question bu then i think u should upgrade the whole pc......
other wise
check the max amount of RAM supported by the mobo.
and upgrade to that amount...i doubt it wil be 1gb or more
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
gcc probs Vivek788 Open Source 10 19-10-2007 03:22 AM
net probs in qd montsa007 Mobiles and Tablets 1 27-05-2006 01:14 AM
C++ probs... legolas Open Source 2 01-05-2006 07:34 PM
Upgradin HDD on P-III config... gauravakaasid PC Components / Configurations 3 21-12-2005 10:43 PM
