Old 09-01-2008, 02:28 PM   #1 (permalink)
hell boy
Question USB problem
hey,
i recently updated my bios to the latest available of my motherboard{asus m2n-mx} and now my usb ports do not work at 2.0 .
i have a external hard disk so it need higher data transfer and now it is very slow. about an hour to copy 6.5 gb what the f***& .
i am very much confused i even get the msg "this device can perform better wgen connected to 2.0 port" like this or somthing
HELP ME OUT
like sly stallone i am bringing the pain the only difference is that i got SINGH in my name..,!!
MasterMinds is offline
Old 09-01-2008, 02:48 PM   #2 (permalink)
Jags's Avatar
Default Re: USB problem
give this a shot:
first, uninstall ALL the usb drivers from the device manager..restart..windows will now install the drivers again.
if this doesnt work then the its better that u go back to ur previous bios, of which u have hopefully made a backup.
Jags is offline
Old 09-01-2008, 02:51 PM   #3 (permalink)
hell boy
Originally Posted by Jags View Post
give this a shot:
srry tried it not a worth
and going back to first bios is not the option cause with that bios bord wont recognize th processor n thats the cause i updated my bios
i have even tried installing fresh copy of windows and derivers>>>
in vain
Old 09-01-2008, 05:08 PM   #4 (permalink)
Fast 'N' Furious
topgear's Avatar
Try to re-install your OS
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 10-01-2008, 11:59 AM   #5 (permalink)
Jags's Avatar
give this a shot:
tried the tech support on their website
Jags is offline
Old 10-01-2008, 03:27 PM   #6 (permalink)
smile's Avatar
Talking Re: USB problem
@ top gear: U cant understand what he has written ....he has already installed the OS
SR
smile is offline
Old 10-01-2008, 03:47 PM   #7 (permalink)
TheSaint
NucleusKore's Avatar
Go to device manager, open your usb and select update driver
I have detailed it here
usb 2.0 problem
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Old 10-01-2008, 03:51 PM   #8 (permalink)
vaibhavtek
Posts: n/a
ya just go to ^^ link.
Old 12-01-2008, 04:39 PM   #9 (permalink)
Fast 'N' Furious
topgear's Avatar
My mistake
topgear is offline
Old 12-01-2008, 05:12 PM   #10 (permalink)
anand1's Avatar
@nucleukore thanks for the info.
Technology On The Fly
anand1 is offline
Old 12-01-2008, 09:05 PM   #11 (permalink)
TheSaint
You're welcome
Old 13-01-2008, 04:18 PM   #12 (permalink)
Fast 'N' Furious
topgear's Avatar
@ MasterMinds
One last try:
Navigate through all of your bios optinons.
Find a setting something like Onchip Usb or usb mode or usb speed or usb compatibility.
Check if it is set to usb v1.1+v.2.0 or v.2.0. If its
value is set to usb v1.1 or Legacy mode then change it to v.1.1+2.0 or v.2.0.
That should solve your problem.
one exaple to clarify the whole process. According to my mobos bios
my usb settings located at Integrated Peripherals > USB Config > Onchip USB :
Here I have three options to choose from :
1. USB v.1.1+v.2.0 ( Default or Normal Value )
2. USB v.1.1
3. Disabled
Last time i upgraded my bios xp showed on task manager that I've
only one cpu core while i've a dual core cpu. So I checked my bios settings
& found that one among of two cpu cores was disabled. So I enabled that
disabled core manually & that solved my problem.
topgear is offline
Old 16-01-2008, 03:01 PM   #13 (permalink)
hell boy
Originally Posted by topgear View Post
@ MasterMinds
One last try:
2. USB v.1.1
3. Disabled
i tried that also
Old 16-01-2008, 03:49 PM   #14 (permalink)
At Hell's Disq
hellgate's Avatar
^^^ download the latset chipset driver.uninstall the old chipset drivers,reboot and then install the latest chipset drivers.
if ur already running the latset chipset driver then uninstall it,reboot and reinstall.
hellgate is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
