Old 09-01-2008, 12:35 PM   #1 (permalink)
Default Getting a error msg the "Virtual Memmory Low" -reg
hi mates,
well, i m in trouble while downloading with my Lappy - LG Xnote RD400. that,
i havint maid any partition in my 160gb HD. and having 1gb ddr. i used to dwnload a lot of study meterials frm net. now my HD got filled 90gb out of 160. now, whenever i am trying to download some thing, wh contain 50mb or more, cant get downloaded, and showing a message that, "your Virtual Memmory is low, ..."
pls be kind to help me in this regarding.
be kind, i am in need to get guided frm.
thanking you in advance
yours faithfully
mobileman
mobileman is offline
Old 09-01-2008, 12:40 PM   #2 (permalink)
a_g = JPKN
s18000rpm's Avatar
Default Re: Getting a error msg the "Virtual Memmory Low" -reg
how much VM have you allocated right now?
http://www.thinkdigit.com/forum/show...33&postcount=2
virtual memory problem!!!!!!!!
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 09-01-2008, 12:59 PM   #3 (permalink)
hi s18000rpm,
thanking you for your refference and instant reply.
well, i have allocated 1024 in min and 1025 in max.
mmmmm
be kind
mobileman
Old 09-01-2008, 01:51 PM   #4 (permalink)
Here Since 2003
Indyan's Avatar
Increase it to 2gb and make the min and max values same.
Which software are you using to download? it is a memory hog?
Check using Process Explorer (technet.microsoft.com/en-us/sysinternals/bb896653.aspx) to see if any process is taking up a lot of ram (like antivirus,virus/trojans etc).
Indyan is offline
Old 09-01-2008, 02:11 PM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
Best things would be to set: System manager swap file. It will take care of any lows and highs.
infra_red_dude is offline
Old 09-01-2008, 04:09 PM   #6 (permalink)
Web Junky 2.0
debiprasad_sahoo's Avatar
It is recommended to make min as 1.5 * (your RAM size), means 1536 (min) at your case. You can also select more than that but not less than 1536. But for maximum, select something more, such as 4GB.
More reason to love orkut
Get Scraps, Testimonials and many more...
http://loveorkut.com/
debiprasad_sahoo is offline
"Virtual Server Setting" on HUWAI SmartAX MT880 nitesh QnA (read only) 1 22-12-2007 06:27 AM
NEW VIRUS GIVING MESSAGE:"Can not find script file"WIN32.DLL.dll.vbs" ". mdp Software Q&A 5 02-10-2007 02:11 PM
VISTA TUTORIAL: Add "Hide File Names" Option in "View" Menu of Folders Vishal Gupta Tutorials 7 27-06-2007 10:46 PM
Pen drive error messg"Unable to open Script file "F:\MSDLL.dll.vbs" janitha Software Q&A 19 20-04-2007 10:25 PM
"INF Error", VGA Driver "Missing" Installing ATI Catalyst Drivers CannedLizard Hardware Q&A 4 29-07-2006 12:47 AM
