Old 08-01-2008, 09:08 PM   #1 (permalink)
Default DVD writer damn slow..I got IMATION dvd writer..
I got a Imation dvd writer..It is not even 1 year old...It was working good in my old com but after since i changed my com to new assembled one wit core 2 duo 2.2ghz 1gb ram and 965 mb i got problems..It worked perfectly after i fixed it in my new computer but after a week it got damn slow and for now writing a dvd it takes almost an hour..It used to take not even 10mins before..Both copying and burning takes the same time a lot..
Mine is Imation DVD writer i guess it is 18x..I checked it in nero info tool firware version is given as PSl1(i dont know wat is firware even though i checked)...And also i include whenever i burn something in the dvd writer or copy something from dvd my computer gets damn slow..mouse becomes shaky...dunoo y it is like tat even though i got 1gb ram ,core 2 duo
Please help me out Advance thanks
(sry for my poor english)
roonie is offline
Old 08-01-2008, 11:10 PM   #2 (permalink)
Default Re: DVD writer damn slow..I got IMATION dvd writer..
Check whether it's running in PIO mode or DMA (device manager ->ide/atapi controllers).
Change to DMA if in PIO.
Let there be music.....
sashijoseph is offline
Old 08-01-2008, 11:30 PM   #3 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Wink Re: DVD writer damn slow..I got IMATION dvd writer..
Yeah it is a PIO mode problem I think.
Indeed sry is Poor english
Do not offending you roonie
debsuvra is offline
Old 08-01-2008, 11:46 PM   #4 (permalink)
Still Shining!
Lucky_star's Avatar
THIS
Nokia N86 8MP
Lucky_star is offline
Old 08-01-2008, 11:56 PM   #5 (permalink)
damn busy...
utsav's Avatar
If all this does not work then chk my tutorial to change pio transfer mode to udma in the tutorials section
MSI GX660 with ATI 5870 :grin: ultimate gaming lappy :grin:
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 09-01-2008, 03:15 AM   #6 (permalink)
that DMA reset tool might just work for u..it did for me.my samsung thingamajig now roars..thnx lucky star..lucky 4 me indeed, eh?
apacheman is offline
Old 09-01-2008, 02:40 PM   #7 (permalink)
Still Shining!
Lucky_star's Avatar
Glad its working.
Nokia N86 8MP
Old 09-01-2008, 07:44 PM   #8 (permalink)
thanks for the replies..i checked out the tranfer mode is in"DMA if available "only..
But in nero info tool it is showing as DMA oFF..wat should i do now??
oh ya it was off..it got switched on after i did tat wit dma reset tool..but no difference der..for copyin 50mb it took 30seconds
roonie is offline
Old 09-01-2008, 07:55 PM   #9 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Exclamation Re: DVD writer damn slow..I got IMATION dvd writer..
If there is no effects after enabling the DMA, then your IDE cable is not compatible with UDMA 5.
debsuvra is offline
Old 09-01-2008, 08:05 PM   #10 (permalink)
wow cool..its fast now..gr8 guys i dint know i wil get a result so soon thanks a lot..its copyin process takes 1gb almost 2mins is it the actual speed??..but its better then before and my com is normal while copyin it was shaky and gets slow wen some process going on in drive before..
roonie is offline
Dvd writer burning very slow...It takes more than an hour , some times stops halfway jvijay86 QnA (read only) 17 10-01-2008 12:56 AM
got a new dvd writer Samsung Super WriteMaster 18x DVD Writer xbonez Hardware Q&A 7 14-08-2007 02:10 PM
dvd writer getting very slow. mgupta Hardware Q&A 6 23-07-2007 09:29 PM
Dvd writer running too slow... magneticme200 Hardware Q&A 5 29-04-2007 01:48 PM
slow cd writer varunbhide QnA (read only) 6 11-04-2005 08:16 PM
