Old 08-01-2008, 08:38 PM   #1 (permalink)
Question Which Motherboard Should I Go For???
I have Intel 865GV Motherboard (Having AGP interface only), Pentium 4 with Hyper Threading Technology (HT) Processor 2.8 GHz (This processor has pins) and 512 MB DDR RAM. Now I've Purchased a XFX 8600GT Graphics Card which requires x16 PCI-Express Slot. So I want to upgrade my Motherboard to support this graphics card without changing my processor though I can change my RAM to DDR2 if required. So which Motherboard should I purchase as the current gen Motherboards (like 915, 945, 965 etc) are not compatiple with my processor.
Please suggest a motherboard which will solve my problem.
thunderwonder is offline
Old 08-01-2008, 11:15 PM   #2 (permalink)
Default Re: Which Motherboard Should I Go For???
Man change your proccy as well.Finding a new socket 478 board is next to impossible and with PCIe...well no way.
Let there be music.....
sashijoseph is offline
Old 09-01-2008, 03:02 PM   #3 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
dude best way to go for an AMD setup. Will cost ya almost 4-5K for a good decent combi and have great performance and u can use ur card too.
Just think it like this way...it shall be better than ur current config.
keith_j_snyder2 is offline
Old 09-01-2008, 03:13 PM   #4 (permalink)
I M A *STAR*
saqib_khan's Avatar
yes, i agree with keith_j_snyder2
Blogging at:
Technostarry
saqib_khan is offline
Old 09-01-2008, 03:33 PM   #5 (permalink)
P4 and 478 is cave man. Just get a AMD64 X2 + Asus M2N MX SE Mobo
and as you got 8600 GT this will be a very good machine. You can use your exisitng HDD, FDD, Optical Drive with it and also cabinet. Sell of the DDR ram and get some DDR II the net price difference will not be much at all.
Phenom II 955 BE @ 4.12 Ghz | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Seagate : 1 TB | NZXT Phantom 410
Elite 335 Cabinet @ 0.8K http://www.thinkdigit.com/forum/baza...ite-335-a.html
Tech_Wiz is online now
Which motherboard sud i go for?? Manshahia Hardware Q&A 23 31-05-2007 09:00 PM
CPU + Motherboard tharkiman Hardware Q&A 3 20-01-2007 07:24 PM
motherboard Dharamveer Singh Grewal Hardware Q&A 3 20-02-2006 11:36 PM
which is the best amd motherboard vikas_r_s Hardware Q&A 35 04-02-2006 08:10 PM
