Old 08-01-2008, 08:13 PM   #1 (permalink)
Default Which is better AMD 690g based Mobo or nvdia 430
HI,
i plan to buy a system based on one of these chipsets. now all i want to know which one to buy...
i think since x1250 is better than 6150 so i preffered 690g based mobo.
i finalised on asus m2a-vm...but i saw some benchmarks on net and they conclude that other than gaming overall both are equivalent...
now i need some good mobo models based on nvidia's equivalent chipset...
and suggestion for any other motherboard...
also mobos having IGP as 7050...
my budget for mobo rs. 3-3.5k..
vinay_001 is offline
Old 08-01-2008, 09:14 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: Which is better AMD 690g based Mobo or nvdia 430
Which proccy do u have?
Pathik is offline
Old 08-01-2008, 09:30 PM   #3 (permalink)
dOm1naTOr's Avatar
Asus M2N VM DVI is a gud mobo with 7050 nd is only some 150~200 bucks more expensive than M2A VM.
With M2A VM, ull have to stick with the bundled drivers as none of other drivers won't work with it[even one which is said to support X1200 series].
But with 6100, 6150 nd 7050, any nvidia drivers wud work due to unified drivers.
Thnx to nvidia, they rox in driver release.
I myself have M2A VM, nd is satified with its performance compared to other IGP out there.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
What is 690G??? Kalyan Hardware Q&A 3 30-05-2007 08:29 PM
NVIDIA GeForce 6150 Or AMD 690G ruturaj3 Graphic cards 9 19-05-2007 05:13 PM
nforce4 chipset based mobo wanted mandar5 CPU / Motherboards 1 01-01-2006 11:09 AM
does intel 915 chipset based mobo supports hardware T&L arunbj CPU / Motherboards 5 26-07-2005 07:25 PM
nvdia geforce 4 mx sujeet2555 Gamerz 4 26-06-2005 12:58 PM
