Old 08-01-2008, 03:04 PM   #1 (permalink)
Default Sound card help required to run speech to text software.
Does my Gigabyte GA-MA69VM-S2 ATI Radeon. 690 V MOBO supoort 16 bit recording.It has realtek for sound drivers.If my MOBO doesnt support that, could some one please suggest me a good 16 BIT sound card.My budget is 2k.Should i go for 24 bit instead?Whats the advantage? Could some also please help in choosing a good MIC for recording. im planning to use it for voice recognistion.
krinish is offline
Old 09-01-2008, 12:02 AM   #2 (permalink)
Default Re: Sound card help required to run speech to text software.
Yeah the onboard audio would easily support 16 bit full duplex operation.
For the mic,if you have the budget,go for a Shure SM56 or SM57(~2-2.5k).
Let there be music.....
sashijoseph is offline
Old 09-01-2008, 03:13 AM   #3 (permalink)
nah..onboard would suffice
apacheman is offline
Old 09-01-2008, 12:36 PM   #4 (permalink)
Any good Microphone? Budget 2K. Will be used for speech to text.
krinish is offline
Old 09-01-2008, 01:06 PM   #5 (permalink)
Beware of the innocent
ilugd's Avatar
shouldn't any local microphone work? Shure is only needed if you are into professional audio. I use a Rs. 50 microphone I got from Nehru Place for my audio works. Not sure if it is good enough for voice recognition though.
Life is too short. Have fun.
ilugd is offline
Old 09-01-2008, 02:32 PM   #6 (permalink)
I suspect if any ordinary Microphones would be competant for speech to text.
I used IBM Via voise before and it was extremely tough to get my Microphone type what i wanted to do.
When u intially set up such Software, u will require to train it with your voise, and a powerful microphone would come in very handy.
Im planning to use dragon naturally speaking now.
krinish is offline
Old 09-01-2008, 02:39 PM   #7 (permalink)
ilugd's Avatar
hmmm... In that case, if you do go for good microphones, be sure to tell the shopkeeper what exactly you want it for. there are different types of professional microphones and you need one exactly suited for vocals.
ilugd is offline
text to speech software need,have to save as WAV mobileman Software Q&A 4 18-02-2007 02:18 PM
External Sound Card Required Anderson QnA (read only) 1 11-08-2006 07:29 AM
Suggest text to speech software ranjan2001 Software Q&A 7 30-07-2006 12:34 AM
"Text-To-Voice/speech" Software. nil_3 Software Q&A 10 22-03-2006 11:17 AM
need a speech to text kingshere Software Q&A 13 15-02-2006 02:32 AM
