07-01-2008, 09:52 PM
Mouse jerking randomly
I bought a new optical mouse Samsung pleomax.
Strange thing with it is that either the mouse pinter jumps to the side of the screen randomly or it start jerking slowly to 1 side & I can see the mouse pointer moving.
I uninstalled & reinstalled it but that does not solve te problem, the mouse did not came with any driver so I am using the XP inbuilt driver which was used with earlier mouse also & it worked fine.
What could be the problem, is the mouse faulty?
07-01-2008, 10:10 PM
At Hell's Disq
Re: Mouse jerking randomly
is it a PS/2 or USB mouse?
07-01-2008, 10:28 PM
Its PS/2 connector
07-01-2008, 11:02 PM
At Hell's Disq
try the mouse in a diff pc.if problem persists then mouse is faulty.
07-01-2008, 11:12 PM
Still Shining!
Simple... Use a Pad having cotton or velvet top
Nokia N86 8MP
07-01-2008, 11:14 PM
At Hell's Disq
^^^ optical/laser mice can be used on most surfaces without using a mouse pad
07-01-2008, 11:17 PM
Still Shining!
Yah, but on very shiny and reflective surfaces like a computer table or glass sheet, such problems arise.
Nokia N86 8MP
07-01-2008, 11:40 PM
On ur suggestion I used a newspaper / book top/ mousepad/ underneath the mouse but the jerking still is the same, my old optical mouse works perfectly on my computer table top.
08-01-2008, 12:05 AM
Still Shining!
oho, then can be a Hardware problem. Change the "Reports per second" to 200 in the mouse hardware properties and see.
Play with those settings(increase or decrease) till you get a steady pointer.
Nokia N86 8MP
08-01-2008, 11:23 AM
there can be two possibilities
1) faulty mouse
2) faulty pad
it happens to me too...........my pad is faulty....
eXPerience is what a MAN learn's fROM.....
08-01-2008, 11:26 AM
Think Zen.
Yep, happened to me too,
Faulty pad, removed it and t'was fine.
And i use a samsung mouse too.Not PleoMax though.
Regards,
ray
Do what you will; but not because you must. -- Zen Quote
08-01-2008, 12:57 PM
Ok let me try this & I will report back if it works or not , though my last mouse was working fine at these default settings.
I dont understand this, how can be a pad be faulty? its just a rubber/velvet/cloth surface.
08-01-2008, 07:07 PM
i had a same problem last month but now i am using black colour pad and no more mouse pointer problem
maybe faulty mouse hardware is responsible
08-01-2008, 08:40 PM
Lucky_star
I changed the setting to 200 & got a new mouse pad but the problem still remains, the mouse still jerks & jumps randomly.
Seems I need to go for a replacement.
08-01-2008, 08:49 PM
Still Shining!
Then, you have the last option left: Bring home a new mouse
Nokia N86 8MP
08-01-2008, 09:15 PM
dá ûnrêäl Kiñg
buy a black optical mouse pad,dont use ordinary mouse pad.
My Stomach pains:D:D
http://tinyurl.com/32jj4m
08-01-2008, 09:25 PM
In rare cases, the problem will be with the sensor[ponter jumps to screen corner]. It can be minimised by some tricks like opening the mouse nd attaching alluminium foils for better channeling of the light to underside of mouse. But 100% cure is not possible.
And if u get a new one, buy Microsoft basic. They are gud, but feel too weightless. U can open it nd attach some weights with bus nd bolts nd make it better for gaming.
And get some cloth surfaced mouse pads.
G3: XPS M1530 |
FZ 16.
08-01-2008, 11:07 PM
Originally Posted by zyberboy
buy a black optical mouse pad, don't use ordinary mouse pad.
I have never used a pad with my optical mouse so don't know much are there specific mouse pad for optical mouse?
Meanwhile I checked the mouse on both XP & vista & in both cases it jerks so it is indeed hardware problem. Need to get it replaced.
09-01-2008, 07:52 PM
#19 (permalink)
dá ûnrêäl Kiñg
Mouse pad for optical mice is available,it will increase accuracy.
09-01-2008, 09:47 PM
#20 (permalink)
How much is it available for & what price approx?
Is this a pad for optical mouse.
http://hardware.gotfrag.com/files/up...sepads_f30.jpg
Reason: Automerged Doublepost
09-01-2008, 09:53 PM
#21 (permalink)
dá ûnrêäl Kiñg
^^the pic,dont know if its op Mouse pad
I hav one cheap optical mouse pad which cost 25/-
and its texture is different from ordinary mouse pad.
09-01-2008, 11:09 PM
#22 (permalink)
OK understood I have seen those textured mouse pads.
10-01-2008, 02:17 PM
#23 (permalink)
Boy Waiting To Be A Man!!
my old mouse used to jerk after quite some time ... but i thot its time was over so i replaced it ... most probably a hardware problem as my mouse started behaving that way only when i threw it on wall 7-8 times
counterstrike on lan makes u do that sometime .. lol
With No Power Comes No Responsibility !!!
-Clark I
14-01-2008, 02:17 AM
#24 (permalink)
100% problem with Mouse, replaced it and if possible in exchange ask for MS basic Optical Mouse V2 (don't go with V1), you never repent for this buy trust me, I'm one of the person who harassed by all budget mouse and finally got replaced my Jumoing mouse with MS V2 mouse and I feel like heaven.
Why don't you allow HTML signature?
31-01-2008, 04:07 PM
#25 (permalink)
I got the mouse replaced, but surprising fact is that these Samsung Pleomax optical mouse is being marketed by Jupiter info Ltd & I saw 11 guys coming for replacement with the same jerking issue which I was complaining.
So be careful before u but this mouse.
Now I get to face the other problem
My old mouse is functioning & I find a strange problem that with the new mouse I have to move the mouse more distance to cover the full screen, where as the old mouse does the same within less distance.
What could be the issue?
31-01-2008, 09:56 PM
#26 (permalink)
Still Shining!
Control Panel->Mouse->Pointer Options->Select Pointer Speed
Nokia N86 8MP
31-01-2008, 11:37 PM
#27 (permalink)
Thanks that solved the problem but what does (enhance pointer precision) do?
01-02-2008, 01:13 PM
#28 (permalink)
Fast 'N' Furious
Even I am facing same problem with i-ball laser mouse with usb interface
Replaced it 2 times as both of those mouse stop working ie the pointer frozen on the middle of the screen.
Now I'am facing this jerking prob with the newly replaced mouse
I doubt every i-ball laser mouse have some serious problems.
So bought a new frontec optical mouse last month.
