Old 07-01-2008, 06:27 PM   #1 (permalink)
UBERGEEK
PCWORM's Avatar
Smile Suggest a gud CPU within 15k.
Hi all..
im thinking of upgrading to new cpu...pllz suggest the best possible configuation...!
thnx in advance!!
And here comes the crysis killer: http://in.youtube.com/watch?v=Cd-LPHZcLNQ
PCWORM is offline
Old 07-01-2008, 06:29 PM   #2 (permalink)
Default Re: Suggest a gud CPU within 15k.
please state the componets u need
juggler is offline
Old 07-01-2008, 06:32 PM   #3 (permalink)
anand1's Avatar
Q6600.
Technology On The Fly
anand1 is offline
Old 07-01-2008, 06:37 PM   #4 (permalink)
UBERGEEK
PCWORM's Avatar
Smile Re: Suggest a gud CPU within 15k.
I want dese components...
1. MOBO
2. Processor
3. Ram
4. HDD
5. Powersupply
6. Cabinet
PCWORM is offline
Old 07-01-2008, 06:50 PM   #5 (permalink)
Noobie Pro
alsiladka's Avatar
Just today i got myself a new machine, AMD X2 5600+, ASUS M2N-VM HDMI, Transcend 2Gb 800MHz RAM, LG 20x DVD Writer, Hitachi 160GB Sata II HD, VIP 820 Cabinet. All in 17K, You can possibly save 1K on the Proc by going for 5200 and 1K on a lower spec MB.
If you want to compare the benchmarks of various Intel and AMD Cpus, you could refer these excellant year end reviews by Tom's Hardware
And for the prices, you can refer TheITWares. The prices in your area may differ by a 100 200 rs plus minus.
www.twitter.com/alsiladka
alsiladka is offline
Old 07-01-2008, 06:55 PM   #6 (permalink)
UBERGEEK
PCWORM's Avatar
thnx man...!! ill see d link 4 comparison....wots the chipset of ur mobo?
PCWORM is offline
Old 07-01-2008, 07:03 PM   #7 (permalink)
dOm1naTOr's Avatar
if u want all that for 15k then AMD is the way to go.
go to this thread nd ull get reply
Basic Guide Purchase a New System
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 07-01-2008, 07:08 PM   #8 (permalink)
1. processor AMD X2 5200+
2. Motherboard Asus M2A- VM or M2N-VM
3. Transcend 800 Mhz 2 gb ram
4. seagate sata 2 hdd 160 Gb
5. Zebronics or Vip cabinet
6. Liteon DVD writer 20X
This config would cost around 15 K
juggler is offline
Old 07-01-2008, 07:10 PM   #9 (permalink)
UBERGEEK
PCWORM's Avatar
Thnx arvind and juggler!!
PCWORM is offline
Old 07-01-2008, 11:35 PM   #10 (permalink)
Noobie Pro
alsiladka's Avatar
I would not suggest LiteOn. If any problem, you will have to send it to Mumbai and it will take 15 days.
I just saw you are from pune, even i am from pune. I know the Computer World guy on Karve road. If you want, i would get you a nice deal there, and ya, no hidden incentives for me except a machine from his shop from my friend
My MoBo was 4.5K.
Old 08-01-2008, 02:33 PM   #11 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Yeah u are right!
Always keep in mind about the warranty and service center especially for ROMs and Writers because they get errors easily!
keith_j_snyder2 is offline
Old 08-01-2008, 07:42 PM   #12 (permalink)
UBERGEEK
PCWORM's Avatar
My MoBo was 4.5K.
okay..ill contact u when time comes!
PCWORM is offline
Old 08-01-2008, 08:50 PM   #13 (permalink)
UBERGEEK
PCWORM's Avatar
Ive finalised 2 options 4 ma rig..
1. AMD Athlon X2 5600 with ASUS M2N-VM DVI.
2. Intel Core2 duo E6420.
Which 1 shud i go for???
PCWORM is offline
Old 08-01-2008, 09:22 PM   #14 (permalink)
Google Bot
Pathik's Avatar
Get the 5600+ with the m2a/m2n vm.
Pathik is offline
Old 09-01-2008, 02:58 PM   #15 (permalink)
Rising ApocalypsE
Yeah 5600+ is great processor for non-overclockers!
Keep in mind that u only buy those 65 watt brisbane core!
Those are less power hungry!
Old 18-01-2008, 11:46 AM   #16 (permalink)
UBERGEEK
PCWORM's Avatar
Well,, sorry bro,, i got ma config from the "IT mall" guy, near agriculture-coll ground... my dad knows him,,, we didnt consider him bfore, but got into a deal when he gave a reasonable estimate...i got got d machine for 17.5k..
neways thanks 4 ur help regarding th computer world guy...
hey,,i jus got d same config as u,,, jus telme which games uve tried on the machine...ive tried only NFS_Carbon for now...nd it played well,,,wid medium settings...
PCWORM is offline
Old 18-01-2008, 02:03 PM   #17 (permalink)
Noobie Pro
alsiladka's Avatar
Hey no probs, congrats on the new machine.
Just one downside The onboard GFX card aint too great!! I am playing C&C - Generals, it plays all well.
All the new games lag a bit, and you cannot run them on high quality GFX settings. If you are into games a lot, i suggest you get yourself a dedicated GFX card.
You got the same cabinet? I added 3 additional fans to it
Old 18-01-2008, 02:33 PM   #18 (permalink)
UBERGEEK
PCWORM's Avatar
No ive got d same system as u except the cab....
As far as the graphics card is concerned,, it wil b okay 4 me coz i dont play much games on mah pc...i do hav an x360 for that... the only thing i expected
this machine to do well was at 3D softwares like 3ds max, inventor, and sum
engineering related ones like PRO-E, CATIA.....and to my surprise,, it blowed
them all wit no frills....!!!!!!
Hav u got any new driver for the mobo and the processor?...ive installed amd-dual core optimiser.
PCWORM is offline
Old 18-01-2008, 07:45 PM   #19 (permalink)
Noobie Pro
alsiladka's Avatar
Are you using XP? I have Vista so maybe drivers and softwares would be different. Vista does not need (or has) the DUal Core Optimiser from AMD. As for the drivers, i used the Cd's drivers for the Mobo and downloaded the Latest GFX drivers from nVidia.com
Suggest a gfx napster007 Graphic cards 5 05-09-2007 10:36 PM
Suggest the Best!!! Maghi Gamerz 7 20-06-2007 01:19 PM
what will you suggest krish Buying Advice 10 04-04-2006 10:54 AM
Suggest a pc for 30k!!!... rockyj123 QnA (read only) 6 13-01-2005 01:53 AM
