Old 07-01-2008, 12:40 PM   #1 (permalink)
Default Tech com Ups Problem
Hi. I recently bought a Ups from Tech com. Suddenly i observed that at times of Power cuts. My System restarts on Ups backup. This Thing doesn't happen every time but it happens frequently. Can you tell me what may be the problem?
Krish_88 is offline
Old 07-01-2008, 12:46 PM   #2 (permalink)
Deadman Walking
Batistabomb's Avatar
Default Re: Tech com Ups Problem
May be a system problem
My computer->properties->advanced->start up and recovery->settings->automatically restart, remove tick mark from this
If this not works, may be a UPS problem, go for desktop properties->screensaver->power
and verify configure settings of UPS
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 07-01-2008, 01:43 PM   #3 (permalink)
Thanks. Will try that
Krish_88 is offline
B.Tech IT Via correspondence xenkatesh QnA (read only) 7 20-02-2007 10:54 PM
Tech 2 [ibn cnn] SE><IE QnA (read only) 9 28-01-2007 12:38 AM
tech way anubhavsinha11 QnA (read only) 2 27-08-2005 05:03 PM
mobile hangs ! a new tech problem ? expertno.1 Buying Advice 2 19-05-2005 09:27 PM
