Originally Posted by 2kewl
Hey Guys,
I have a P-4 2.4Ghz - 256 MB RAm - 40 GB HDD for 4 years. Now I've run out of space on it and need to upgrade the HDD. I also want to upgrade the RAM to 1GB and get a DVD writer.
Need suggestions from you guys as you which brand to choose. thx!
Hey...hold on...u r missing some things here.
1) Ur Mobo wont have SATA, it'll have only IDE. So u'll need to get an IDE HDD. But future mobos (say 1 year down the line) wont have IDE interface. So if u buy a new IDE hard disk now, u wont be able to use it when u upgrade your system. (which u'll need to do pretty soon...coz ur current system is outdated already) Also IDE HDDs might be slower than SATA.
2) Same argument holds for DVD writer. If u get an IDE writer, using it in future will be troublesome.
3)Surely ur mobo supports DDR RAM only. 1 GB DDR RAM costs close more than 2000 rupees, and it's a dead investment, coz u cant use it on any of the newer mobos. Plus u can get 2 GB DDR2 RAM for a much lesser price.
My suggestion is this.
Instead of upgrading, sell off ur old system and get a new cheap system.
An AMD Sempron + Mobo + 1GB DDR2 RAM will cost u less than 4.5K, whereas ur 1GB DDR RAM alone will cost u 2.3K. But I would suggest u go for an AMD Athlon X2 atleast.
