Old 06-01-2008, 10:51 AM   #1 (permalink)
Default xbox 360
Can i also join my keyboard and mouse to surf on net and play games ?
And can any one tell me what is price of xbox 360 which have hdmi port ?
frogonfloor is offline
Old 06-01-2008, 01:18 PM   #2 (permalink)
C# Be Sharp !
Zeeshan Quireshi's Avatar
Default Re: xbox 360
The price of Xbox 360 with HDMI port is same as the normal one's . It's just that the HDMI port 360's are newer models and it's on your luck whether you get the older or the newer model .
The Xbbox 360 Core with 2 Free Games costs Rs 14990
There are 10 types of people in the world: those who understand binary and those who do not.
Zeeshan Quireshi is offline
Old 06-01-2008, 04:25 PM   #3 (permalink)
if u asking whether you can connect your mouse and keyboard to xbox360, then NO. you cannot do that.
Xbox360 comes in 3 flavor arcade,normal,elite. all have hdmi port for that extra pleasure.check out the following link.
http://www.xbox.com/en-US/hardware/c...tm?WT.svl=nav#
What doesn't destroy me, makes me stronger.
jamifahad is offline
Old 06-01-2008, 10:28 PM   #4 (permalink)
what is price of Xbox 360 Elite ?
i think we can join check this out
http://www.amazon.co.uk/Xbox-XFPS-Ke...2008270&sr=8-1
Old 06-01-2008, 11:05 PM   #5 (permalink)
C# Be Sharp !
well currently you CAN attach a normal USB keyboard buy not a mouse .
Old 06-01-2008, 11:19 PM   #6 (permalink)
i have wireless keyboard will it work ?
Old 08-01-2008, 01:56 PM   #7 (permalink)
if you can attach a usb keyboard, y cant u attach usb mouse? there is no usb connector in xbox360. i dont get one thing...y do u want to attach keyboard if u getting wireless joystick with the console! anyway know one thing xbox360 is only meant to play games and not surf net. u can play ur hd-dvd as it has hd-dvd drive.
Old 08-01-2008, 11:36 PM   #8 (permalink)
playing some game (age of empire) with joystick is reay difficult..
Old 09-01-2008, 03:19 AM   #9 (permalink)
can u surf the net using the wifi conn in xbox , if it has one?
apacheman is offline
Old 09-01-2008, 09:07 AM   #10 (permalink)
i think no
Old 09-01-2008, 01:33 PM   #11 (permalink)
to surf a net you need a browser..where the hell you gonna get one in xbox?
Old 09-01-2008, 06:43 PM   #12 (permalink)
=--=l33t=--=
ring_wraith's Avatar
If you need a Mouse and KB , then be patient. It is very likely that the Xbox 360 will eventually obtain support for those.
Else, get the PS3 now. It supports Mouse and KB.
ring_wraith is offline
Old 11-01-2008, 11:18 PM   #13 (permalink)
does ps2 have hdmi port ?
Old 11-01-2008, 11:21 PM   #14 (permalink)
Google Bot
Pathik's Avatar
^^ No way man.
Pathik is offline
xbox 360 from uk Shloeb Gamerz 6 01-11-2007 09:24 PM
Microsoft Xbox 360 Elite Review - HDMI and boosted storage for new flagship Xbox mstpblog Gamerz 10 07-09-2007 07:34 PM
xbox or ps2 king rrr Gamerz 19 12-11-2006 08:46 PM
can xbox 360 do this ?? bkpeerless Gamerz 3 09-08-2006 10:59 AM
