Old 04-01-2008, 02:01 PM   #1 (permalink)
Default Hows viewsonic 19" VA1912WB
19" VA1912WB is this monitor any good
from the respect of gaming ?
I there is any ghosting during gameplay or watching movies ??
If possible suggest a better 19" monitor within 10K
Whats the difference between gray to gray and typical response time?
and how much response time is required for gaming on LCD monitor
juggler is offline
Old 05-01-2008, 10:38 AM   #2 (permalink)
The Frozen Nova
casanova's Avatar
Default Re: Hows viewsonic 19" VA1912WB
Viewsonic 19" VA1912WB is pretty decent monitor. I am using it since 10 months without any issues. However, with the downfall of prices I would suggest you to buy a monitor with HDMI port. Viewsonic 19" VA1912WB comes with an Analog and DVI port.
I dint experience any lag whatsoever.
Try monitors from Samsung
Response time upto 8ms is pretty good.
www.nerdweed.blogspot.com
casanova is offline
Old 07-01-2008, 10:11 AM   #3 (permalink)
Thanks, I wont be needing a HDMI port as my PC has only DVI port.
do fps games like farcry, Counter strike etc run without ghosting on ur LCD monitor.
juggler is offline
Old 07-01-2008, 11:54 AM   #4 (permalink)
dá űnręäl Kińg
zyberboy's Avatar
ut2004,cs and all plays well even in my old samsung 17inch lcd(8ms response time).Not even a hint of ghosting.
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 07-01-2008, 12:23 PM   #5 (permalink)
so 8ms response is enough for ghost free gameplay
juggler is offline
Old 07-01-2008, 06:40 PM   #6 (permalink)
The Frozen Nova
casanova's Avatar
Yes, 8ms is good enough. I did suggest go for HDMI monitor if you can afford it, you might some day buy a new Graphic card. The price for a monitor with HDMI won't differ too much. Also to add Viewsonic has removed LCDs with webcams. You can even go for it
casanova is offline
Old 07-01-2008, 06:59 PM   #7 (permalink)
dOm1naTOr's Avatar
@casanova
Monitor with HDMI costs upwards of 20k. And there is no point in getting an HDMI monitor. For a TV,its ok.
DVI can give quality close to HDMI @ half the price. Also the main advantage of HDMI is that it combines HD video + HD sound 5.1 on a single cable. And why do one need sound on a monitor.
I wud say monotors with HDMI are for really pro gamerz who is ready to spend anythin for gamin.
DVI I can easily output 2560*1900 @ 85Hz if u have the rite h/w[GPU]. And it much above 1080p.
And an HDMI port on a monitor doesnt necessarly mean it shud perform gud. It just gives a connectivity of HDMI nd im may support 720p or 1080p according to its specs.
Normal 19" LCD wide runs @ 1440*900 which is way higher than the HD quality, ie 720p.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 07-01-2008, 10:00 PM   #8 (permalink)
At Hell's Disq
hellgate's Avatar
Viewsonic VA1912wb is a good monitor.in 10k u can easily get a Dell 19"wide.
hellgate is offline
Old 08-01-2008, 09:43 AM   #9 (permalink)
some sites have recommended Viewsonic 19" VG1930WM as a good LCD monitor is it so?
About dell there is no more online purchase option ?? why ??
juggler is offline
Old 08-01-2008, 10:23 AM   #10 (permalink)
The Frozen Nova
casanova's Avatar
Oh, I dint knew there was such a huge difference for HDMI capable monitors.
Viewsonic monitors are good, you can trust them. VA1912wb is more than year old now. You can definitely try newer ones, like the once with inbuilt webcam. I don't remember the model no, but its ad was present in Digit some months back.
casanova is offline
Old 08-01-2008, 01:51 PM   #11 (permalink)
At Hell's Disq
hellgate's Avatar
if u live in a big city then chances r that u shall get Dell products from a few vendors.
if u can increase ur budget then go for HP W1907.its agr8 monitor.
i wont suggest Viewsonic VA1912wb cuz it has backlight bleeding prob (though bleeding is small).
hellgate is offline
Old 08-01-2008, 04:47 PM   #12 (permalink)
I stay in mumbai. do you know any vendor keeping dell monitor in his shop in mumbai??
juggler is offline
Old 08-01-2008, 04:48 PM   #13 (permalink)
dá űnręäl Kińg
zyberboy's Avatar
and buy monitor only with dvi interface
zyberboy is offline
Old 08-01-2008, 04:52 PM   #14 (permalink)
Rebooting
Choto Cheeta's Avatar
Support some what poor... and for information i own 2 view sonic TFT personal suggestion try not to buy from them and support is really really slow... but un-like dell and acer or hcl, they dont arguee much before issuing a replacement order yes they take a really long time to come up with a replaced product..
I have seen they only have support tools for VA seriese vg / vx users are asked to wait 3/4/5 months for the replacement unit
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 10-01-2008, 10:31 AM   #15 (permalink)
3/4/5 months Ahhhhh!!!!
juggler is offline
Old 10-01-2008, 10:56 AM   #16 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Wow thats real slow...may be they should give after 1-3 year....u know after the warranty expires!
keith_j_snyder2 is offline
Old 10-01-2008, 08:08 PM   #17 (permalink)
At Hell's Disq
hellgate's Avatar
sorry i cant help u on this count.ask any1 whos from mumbai.
hellgate is offline
Old 11-01-2008, 12:25 AM   #18 (permalink)
Rockstar11's Avatar
ViewSonic's 19' VX1932wm widescreen LCD
Contrast Ratio - 2000:1
Response Time - 2ms
http://ap.viewsonic.com/in/products/...ecs.php?id=317
Rockstar11 is offline
Old 11-01-2008, 01:03 AM   #19 (permalink)
Rebooting
Quick Review - Super flop View Sonic vx1932wm
rebooting
ChotoCheeta.com
Old 11-01-2008, 01:14 AM   #20 (permalink)
Rockstar11's Avatar
aila... thank u sir
bacha liya..
Old 12-01-2008, 12:13 PM   #21 (permalink)
shadow hunter
vivekbabbudelhi's Avatar
dell SE198WFP.....is what u need
knowledge can be shared & must be BUT intelligence CAN'T be
vivekbabbudelhi is offline
Old 12-01-2008, 12:36 PM   #22 (permalink)
ya i am now changed my mind toward dell SE198WFP monitor
The sales representative has quoted it around 10500 rs
is there any way to get discount on it???
juggler is offline
Used ViewSonic® VA1912w 19" LCD emailaatif786 TVs / Monitors 2 13-08-2007 03:44 PM
Samsung 19"W Vs Viewsonic 20" W TFT Monitors blacklight Hardware Q&A 12 22-05-2007 07:27 PM
Viewsonic LCD 19" Widescreen pulkit101 Hardware Q&A 6 09-12-2006 10:05 PM
Viewsonic announces "1ms" Response Time LCDs jamyang312 Technology News 1 09-02-2006 07:38 PM
