Old 04-01-2008, 09:44 AM   #1 (permalink)
Torrent Lover :)
akshaykapoor_3's Avatar
Arrow Problems wid my new PC !!
Hi guyz..
Please review my new pc config nd help me with some problems m facing..
Intel Quad Core Q6600@2.4Ghz
Intel board DG33FB
2 GB Dynet 667Mhz DDR2 RAM
Viewsonic 19" wide (VG1921wm)
Now coming to d prob..m running XP SP2 nd vista ultimate..
I see horizontal lines moving up my LCD display screen...they go off aftr sm time nd den dey r back agin...i tried updating all f my display drivers bt nthng wrkd out..
Secndly,
d pc often gives BSOD errors...
which inlcude (PFN_LIST_CORRUPT, IRQL_NOT_LESS_OR_EQUAL etc etc..)
Cud dat b a prob wid my RAM ?...
wat cn i do nw ?
akshaykapoor_3 is offline
Old 04-01-2008, 09:52 AM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: Problems wid my new PC !!
Possible causes:
1) Bad RAM stick
2) Bad hard disk
3) High CPU temperature.
Also install latest directX..and latest driver for ur graphics card.
ravi_9793 is offline
Old 04-01-2008, 10:21 AM   #3 (permalink)
dOm1naTOr's Avatar
Can u posts the system events in eventlogger.
Just after he restart after a BSOD, go to run/'eventvwr'
nd see the system tab, nd post the one marked red.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 04-01-2008, 09:35 PM   #4 (permalink)
moshel's Avatar
"IRQL_NOT_LESS_OR_EQUAL"
thats definately a RAM error...ur RAM stick has gone bad...I have faced this problem thrice in the past...
moshel is offline
Old 04-01-2008, 09:53 PM   #5 (permalink)
dOm1naTOr's Avatar
Try reducing ram timings, especially the divider. Set it at 2T, if it was 1T. Dynet rams are worse. It won't oc over 5Mhz and cannot accept any other latency value other that default.
G3: XPS M1530 |
FZ 16.
Problems and more problems with Linux phreak0ut Open Source 25 16-11-2006 09:38 PM
usb problems vikramkh Hardware Q&A 3 24-06-2006 12:32 PM
PC PROBLEMS daumaster QnA (read only) 2 02-05-2005 08:51 PM
Problems with MGS DKant Gamerz 9 28-03-2005 08:34 PM
SOME PROBLEMS vysakh QnA (read only) 1 23-12-2004 04:18 PM
