Old 03-01-2008, 02:41 AM   #1 (permalink)
Default Need mobo n procy.urgent
hey guys..i just bought the folowing..now just waitin to buy mobo n proc..budget 13k around..plz sugest..i was thinkin of E6550 + xfx 650i ultra..or anythin in amd?
8800GT,2Gb trans,coolmaster 500w,liton dvd writer,250gb hdd,samsung 932NW 19 inch.
need a nice decent combo..plz sugest..gota buy tomrow only
sonu1983 is offline
Old 03-01-2008, 08:46 AM   #2 (permalink)
darklord's Avatar
Default Re: Need mobo n procy.urgent
Abit IP35-E -------------> 5,800/-
Intel Core2Duo E6750 ---> 7,000/-
darklord is offline
Old 03-01-2008, 10:45 AM   #3 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
if u r going for intel u shud buy at least E6750 as said.....or else buy Amd 5600 which performs better than E6550 in multitasking n cost less for procy+MB
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 03-01-2008, 11:41 AM   #4 (permalink)
Amd 5600 performs better than E6650 in multitasking??
r u sure?
juggler is offline
Old 03-01-2008, 12:47 PM   #5 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
^^yes, wt i hav read in some reviews even 5200 performs better than E6550 in multitasking.
But doing the same job without mixing other jobs,like only using Abobe or playing a game, E6550 easily beats amd 6000
zyberboy is offline
Old 03-01-2008, 01:56 PM   #6 (permalink)
Deadman Walking
Batistabomb's Avatar
AMD 6000,it is better than AMD 5600, 6000 is 200 MHZ higher than 5600
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 03-01-2008, 02:14 PM   #7 (permalink)
could u please post the link of the review
juggler is offline
Old 03-01-2008, 02:27 PM   #8 (permalink)
Noobie Pro
alsiladka's Avatar
Check out the CPU comparisions on Tom's Hardware over here -
http://www23.tomshardware.com/cpu_20...=874&chart=444
Its a tough bet, but if you consider the price considerations, then the amount you would probably shell out for Intel, would get you something better in AMD.
www.twitter.com/alsiladka
alsiladka is offline
Old 05-01-2008, 02:24 AM   #9 (permalink)
thanks guys.i got a 6000+ n asus m2n E ..nice combo..
sonu1983 is offline
Mobo + Procy Chirag Hardware Q&A 2 22-12-2007 12:31 PM
Mobo + procy max 10k The Day Walker! Hardware Q&A 1 10-10-2007 02:15 PM
Help in Buying the Procy Mobo combo! joelf15 Hardware Q&A 12 24-06-2007 11:37 PM
which mobo, procy? xbonez Hardware Q&A 6 06-05-2007 02:04 PM
