hi people i want to buy 2 hardisks.
i am thinking of a 320gb SATA hdd which i will put inside my computer with my existing hdd.
and the other one a 250gb PATA hdd which i will put in a casing to use it as a external hdd.the reason i am buying a PATA hdd is bcoz of lack of avalibility of SATA casings,and i have been told they are costly and unreliable.
now my config is 2.8 p4 with H.T,915 intel orignal mobo.
i am getting the above hdd for-:
320gb SATA - 3700/-
250gb PATA - 2800/-.
i want to know
1.) which company is best??? the vendor tells me segate is best.
but i have a segate 250gb SATA hdd and it makes noise whenever
some data transfer takes place.that is annoying so this time i want to
buy a hdd that makes less noise.
2.) whats with the new SATAII hdd's. are they any good??are they
backward compatible to SATAI??bcoz i think my mobo supports only
SATA I hdd's.
3.) how much does buffer size matter?? i have heard there are 2 buffer
sizes 8mb and 16mb. Can i get 16mb buffer size for my PATA 250gb
hdd also??
4.) i have also heard that there is a segate hdd with perpendicular
recording.Is there a price diffrence between the regular hdd and the
perpendicular hdd.will it be compatible with my motherboard.
also can i get a PATA perpendicular recording hdd for the 250gb hdd i
want to put in the casing??
