02-01-2008, 06:49 PM
Romeo + Lucifer = ME
Lappy problem
Right now i am tryin to install XP SP2 on my frends laptop bu the setup process doesnt recognize the hdd. It loads all files n then gives an error saying that no detectable HDD attached.... Laptop is jus a coouple of days old n reason for installing windows is An Attempt To Get Rid Of Vista
So friends please help me out
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
02-01-2008, 06:58 PM
Deadman Walking
Re: Lappy problem
hard disk detected in BIOS ?
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
02-01-2008, 07:00 PM
Re: Lappy problem
ya.....
Sony Vaio CW26FG
02-01-2008, 07:14 PM
Deadman Walking
Re: Lappy problem
codename , i think you had already vista, so perform chkdsk on it, if it stops then test the hard drive with a diagnostic utility from the mftr website, Usually you will download the file and make a bootable floppy or cd with it. Boot with the media and do a thorough test.If the drive has physical errors, replace it.
Learn to live... &
Live to learn...
02-01-2008, 07:20 PM
Re: Lappy problem
@batista...... i jus installed vista again n it completed without a single problem though i could not partition my HDD....... Its XP SP2 thats not recognizing the HDD........ and please tell me some way to partition HDD after 0S is loaded....
primary 140GB
secondary 10 GB
wantu split the primary partition
Sony Vaio CW26FG
02-01-2008, 07:25 PM
Re: Lappy problem
^^ Disable Sata in your lappy's BIOS and try XP SP2 again... It'll work..!
02-01-2008, 07:38 PM
Deadman Walking
Re: Lappy problem
that's a very very good idea, the problem is max. because of enabling this
primary 140GB
secondary 10 GB
partition manager
Learn to live... &
Live to learn...
Reason: Automerged Doublepost
02-01-2008, 07:41 PM
Re: Lappy problem
partition manager
Experience speaks...
My HP lappy also had the same problem... but searched forums and got this solution.. or the option of slipstreaming sata drivers in xp disc and trying... Opted for the 2nd, and now having a dual boot with vista and XP..!!
Two weeks ago, installed XP on a friend's lappy by disabling SATA..
02-01-2008, 07:49 PM
Deadman Walking
Re: Lappy problem
prasad you are right, i heared this verdict with most of HP lappy
Learn to live... &
Live to learn...
02-01-2008, 10:07 PM
Re: Lappy problem
where do i disable SATA in the BIOS......cudnt spot the location..please specify
Sony Vaio CW26FG
02-01-2008, 10:13 PM
TheSaint
Re: Lappy problem
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
02-01-2008, 10:33 PM
Re: Lappy problem
checking it...... thanks for the link nucleuskore
After disabling the native sata support is it necessary that i have those driver files with me??????
Sony Vaio CW26FG
02-01-2008, 10:40 PM
Wire muncher!
Re: Lappy problem
^^ No. Change the SATA mode from AHCI to IDE in BIOS and install Windows XP. No additional drivers required. Straightforward install
02-01-2008, 11:13 PM
Re: Lappy problem
but cant find the place where to change that mode in BIOS........pls bear wid me n help me out
Sony Vaio CW26FG
02-01-2008, 11:17 PM
Wire muncher!
Re: Lappy problem
Taken from the link posted by NucleusKore:
Disable SATA native mode - Start the notebook PC.
- Repeatedly press the F10 key (or key designated by the notebook PC) until the notebook enters the Computer Setup screen.
- Use the arrow keys to select System Configuration .
- Use the arrow keys to select SATA Native Mode and set the mode to Disable .
Figure 4: Disable SATA Native Mode
- Press the F10 key (or designated key to accept the changes).
- Save changes and exit Computer Setup.
- The notebook should restart.
If this doesn't work then follow the same link to integrate SATA drivers to the Windows XP installation CD.
02-01-2008, 11:23 PM
Re: Lappy problem
i can go upto system config....... but then i dont have the sata native mode thing on this bios......
I downloaded the driver burned them on a cd but the damned setup wil read it only from a floppy drive( where wil i get myself a floppy drive on a lappy ) even tried with usb....... it wanted to install OS on the pen drive
Sony Vaio CW26FG
03-01-2008, 08:24 AM
TheSaint
Re: Lappy problem
Please give me the model number of your laptop
03-01-2008, 01:08 PM
Wire muncher!
Re: Lappy problem
If you don't haf an option for disableing ACHI (native STA) and enabling IDE
then follow the procedure given in the link by NucleusKore to download, extract and integrate the SATA drivers to your Windows XP installatin.
03-01-2008, 01:19 PM
#19 (permalink)
Re: Lappy problem
have a similar problem on DV 2415NR
Can you help? The setup process proceeds after booting from CD, but after the restart, WinXP logo is displayed, then it just shuts down.
No drivers loaded, HDD formatted & clean install, so it cant be a driver issue.
03-01-2008, 06:05 PM
#20 (permalink)
TheSaint
Re: Lappy problem
It is a driver issue. Apparently its a made for VISTA machine. See the solution here
http://jeremyfrombenton.com/2007/10/...ll-windows-xp/
03-01-2008, 10:42 PM
#21 (permalink)
Re: Lappy problem
The xp setup wants the driver from some floppy drive.....but there is no floppy drive on the lappy
Sony Vaio CW26FG
03-01-2008, 10:46 PM
#22 (permalink)
Re: Lappy problem
Have you tried disabling SATA or AHCI in the BIOS..?? What happened?
03-01-2008, 11:13 PM
#23 (permalink)
Wire muncher!
Re: Lappy problem
If you integrate the driver in your XP cd then setup WILL NOT ASK YOU TO LOAD DRIVER FROM FLOPPY DRIVE!
