Old 02-01-2008, 11:58 AM   #1 (permalink)
Default Lappy suggestions
I'm planning to buy a laptop in the range of 30-35K. Please suggest me the good one. I'll basically do some sort of 3D stuff (3DS Max, Maya) on that. I heard that Turion 64 X2s are good.....plz suggest me good model.
parimal is offline
Old 02-01-2008, 12:25 PM   #2 (permalink)
Rebooting
Choto Cheeta's Avatar
Default Re: Lappy suggestions
Rs. 35200/- with 2 GB RAM (upgraded from base 1 GB)
Compaq V6608AU
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 02-01-2008, 12:36 PM   #3 (permalink)
Does this lappy has integrated camera....?? Also any model around 30K??
parimal is offline
Old 02-01-2008, 12:46 PM   #4 (permalink)
Wire muncher!
infra_red_dude's Avatar
For the work you've mentioned I'd sugget you keep away from Turion/Athlon, Pentium Dual Core. you cud go in for Acer Aspire 4710 with Core2Duo Proc. Its available for abt 36k. Other than that I don't think you'll get any laptop wid core2duo under 39k. You may however wud wanna goto acer showroom and check the model out for design and build. Not everyone may like it.
infra_red_dude is offline
Old 02-01-2008, 06:29 PM   #5 (permalink)
yeah....cool. But what's the exact difference between Athlon 64 X2 and Turion X2?? And does this Acer one has decent graphics....??
parimal is offline
Old 02-01-2008, 06:47 PM   #6 (permalink)
TechTin.com
ravi_9793's Avatar
Compaq V6608AU
+1 for compaq V6608
ravi_9793 is offline
Old 03-01-2008, 04:54 PM   #7 (permalink)
cooldude666666's Avatar
hey, better go to http://www.dell.co.in and customize the Dell Inspiron 1520 with 2 GHz Core 2 Duo, 2 GB RAM, 9 Cell Battery, nVidia 8400M 128 MB graphics card, Dell TrueLife TFT etc. I have recently customised one for my friend and it cost hm 49k something...But if you can spend a bit more(read around 2500/-), then you could get nVidia 8600M 256 MB graphics card...They also wave-off the tax if you can wait 5 extra days than the normal delivery...hey, good news for ya...found the specs of that customized lappy.. posting below:
1 Q541202N Q541202N - Dell Inspiron(TM) 1520 Notebook 1 49,057.00 49,057.00
HT137 -Intel(R) Core(TM)2 Duo Processor T7250 1
DX476 -Label (Dual Core & Intel Wireless) 1
BRM-060 -2.0GHz, 2MB Cache, 800 MHz FSB -
UN356 -Genuine Windows Vista(R) Home Basic 32 bit (Engli 1
sh)
NT188 -Genuine Windows Vista(R) Home Basic 32 bit (Engli 1
sh/Hindi) DVD Media
NX325 -System Driver DVD Kit (Vista) 1
UX567 -Microsoft(R) Windows(R) Software Driver 1
DMN-063 -For basic PC use. Improved security and reliabili 1
ty vs. Windows XP.
DMN-064 -Does not include the new Aero graphics interface. 1
MU829 -Dell(TM) Wireless 355 Bluetooth Module 1
XM544 -Dell(TM) PC-Restore 1
DMN-025 -PC Restore will occupy some HDD capacity. 1
DMN-026 -The capacity varies with preloaded material and o 1
perating environment.
WXTX111-IN -1-Year Limited Warranty (Next Business Day Servic 1
e - parts & labour)
WXPH311-IN -1 Year Telephone Technical Support (9am To 6pm, M 1
onday - Friday)
SRVCINTI-1 -Regional Support Within Asia Pacific Countries fo 1
r Notebooks with 1 Yr NBD
IXPS0101-CL -Basic System Installation 1
FRT790-INSP -Inspiron(TM) Handling & Insurance Charges (India) 1
FRT02/790-INSP -Inspiron(TM) Delivery Charges (India) 1
BNC-010 -Integrated 10/100 Fast Ethernet 1
BRM-005 -1 ExpressCard Slot, (DOES NOT SUPPORT PCMCIA CARD -
PU575 -Dell(TM) Travel Remote Control 1
NP091 -Dell(TM) Media Direct 1
PM334 -Dell(TM) Keyboard with Touchpad (English) 1
UW833 -Internal 56K Modem 1
DK903 -Noise Isolation Ear Buds 1
DMN-048 -Approx. 2.0GB of HDD space will be allocated to D -
ell Media Direct.
TH797 -RJ-11 Modem cable (AP) 1
KW181 -Dell(TM) Support Center 1
NR373 -Regulatory Label 1
FP915 -Shipping Mod with Powercord 1
2K159 -Mod Specs Info (India) 1
BMC-011 -8-in-1 media card reader -
R0078 -TV-out Cable 1
UX291 -15.4" Widescreen WXGA (1280x800) Display with Tr 1
ueLife (TM)
PM511 -Jet Black Color with Matte Finish and camera 1
XD717 -2GB (2 X 1024MB) 667MHz Dual Channel DDR2 SDRAM 1
GM519 -Integrated Sound Blaster Audigy ADVANCED HD Audio 1
Software
MN555 -NVIDIA(R) GeForce(TM) 8400M GS with 128MB GDDR2 d 1
edicated graphic memory
UW304 -Base Assembly (Discrete) 1
BFD-008 -No Floppy Drive -
MY607 -160GB SATA Hard Drive 1
WR168 -Internal 8X DVD+/-RW Combination Drive with dual 1
layer write capabilities
XM387 -Roxio Creator 9.0 1
CM132 -McAfee(R) Security Center(TM) – 30 days trial 1
TP270 -Intel(R) PRO/Wireless 3945 Dual Band 802.11a/g 54 1
Mbps Wireless Mini Card
RH778 -90W AC Adapter 1
KU845 -9-cell 85Whr Lithium Ion Primary Battery 1
UF546 -DELL Large Nylon Case 1
RU500 -Shipment Box for Case 1
RMK-002 -Limited time promotional offer only. No further d 1
iscounts apply.
RMK-001 -Discount is only valid if the corresponding upgra 1
ded item is selected above.
Keeping it Posted!!!!!!!!!
cooldude666666 is offline
Old 03-01-2008, 07:18 PM   #8 (permalink)
Wire muncher!
If you forego this:
GM519 -Integrated Sound Blaster Audigy ADVANCED HD Audio 1Software
You can save 1 to 1.5k! Its only the crap software which is available for separate download!
Old 03-01-2008, 09:53 PM   #9 (permalink)
Google Bot
Pathik's Avatar
@cooldude he needs a lappy in 35k..
Also 1520 wont be available in India now.
Pathik is offline
Old 05-01-2008, 06:15 PM   #10 (permalink)
he better not make such a wish cause you can't run 3ds max and maya on a 35k lappy as they would on a 50k one...about the avaiabilty, i'm not quite sure cause i'm buying the same and my order is going to arrive in 10-12 days...
lappy under 35k SunnyChahal Mobiles and Tablets 6 03-12-2007 12:30 AM
Lappy for 42k??? gauravakaasid Mobiles and Tablets 10 05-12-2006 09:49 AM
help me to buy my lappy.. the.kaushik QnA (read only) 7 28-11-2006 10:43 PM
Lappy Lappy Time...!! grinning_devil Hardware Q&A 3 15-05-2006 02:37 AM
lappy for around 60 to 70k Toocool Hardware Q&A 8 04-03-2006 09:29 PM
