Old 01-01-2008, 09:38 PM   #1 (permalink)
Default Wifi
I have a desktop system with wifi adapter and a laptop with wifi i used to connect both through adhoc and share internet . suddenly my monitor conked off and i let my desktop lie idle for a month now that i have got a new monitor and trying to setup wifi both are detecting each other but not connecting . is there a software which when run in both the sytems will automatically connect them in adhoc ?
Dont die of ignorance .
digitizen is offline
Old 03-01-2008, 10:46 PM   #2 (permalink)
Default Re: Wifi
check if the wifi connection is a secured one and needs network key..
What doesn't destroy me, makes me stronger.
jamifahad is offline
Best WiFi Fon Under 15k??? nishantv2003 Buying Advice 3 20-11-2007 10:53 AM
About Wifi vinaypatel Technology News 2 15-11-2006 05:53 PM
I am going to Setup WiFi LAN (WiFi experienced user's views invited) Ricky Hardware Q&A 2 23-10-2006 06:08 PM
