Old 01-01-2008, 03:56 PM   #1 (permalink)
Exclamation HARD DRIVE - Needs Replacement ?
The chkdsk log for this drive is attached.
If i try to copy anything to this drive (a couple of movies) it may copy 1 or 2 files, but after that my PC totally freezes. The num lock key works, but the mouse doesnt move, Ctrl Alt Del doesnt work, nothing. I have to restart using the power button.
Any idea what is happening ?
C:\>chkdsk d: /f
The type of the file system is NTFS.
Volume label is WD250.
CHKDSK is verifying files (stage 1 of 3)...
File verification completed.
CHKDSK is verifying indexes (stage 2 of 3)...
Index verification completed.
CHKDSK is verifying security descriptors (stage 3 of 3)...
Security descriptor verification completed.
244196000 KB total disk space.
230229128 KB in 35467 files.
24984 KB in 2558 indexes.
4 KB in bad sectors.
143784 KB in use by the system.
65536 KB occupied by the log file.
13798100 KB available on disk.
4096 bytes in each allocation unit.
61049000 total allocation units on disk.
3449525 allocation units available on disk.
AMD Athlon 3500+ 939
Asus A8N-E
HDD: 860GB = 250 x2 + 160 x 2 + 40
Nvidia XFX 7600GT
2GB DDR RAM 400Mhz Transcend
17" LCD Viewsonic
ASUS Sata DVD writer
Logitech MX 518 + Steelpad Qck+
CyCo is offline
Old 01-01-2008, 07:33 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: HARD DRIVE - Needs Replacement ?
ur hard disk has 4 KB in bad sectors. .
It will increase daily.best solution is Get it replaced.
ravi_9793 is offline
Old 02-01-2008, 01:26 AM   #3 (permalink)
is it that bad ?? Coz ive never got bad sectors before ?!
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 02-01-2008, 01:30 AM   #4 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
disconnect the hard disk and reconnect again...use another molex(power) connector if possible..and see......if that doent help do a full format.
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 02-01-2008, 01:43 AM   #5 (permalink)
bow chicka bow wow
neeru_igi's Avatar
use a diff ide port if its a pata drive.also try formatting the drive to fat32
Ugraded rig....
C2D e7200, Gigabyte G31s2l , 2Gb transcend (800mhz) ,seagate 250 gb ,nV 8600gt
neeru_igi is offline
Old 02-01-2008, 02:42 AM   #6 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
No matter wat u do i think u stil got to replace it....
if its under warranty then rush n get it replaced
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 02-01-2008, 08:06 AM   #7 (permalink)
TechTin.com
ravi_9793's Avatar
I tell you..dont do much experiment.It has bad sector..and for this best solution is get it replaced.
Old 02-01-2008, 10:03 AM   #8 (permalink)
jatt's Avatar
re-partition will definetly solve your problem so re-partition your hard disk with any third party software and install windows with antivirus then check it out and write here.
ਨੋ ਗਰਲ ਫਰੈਂਡ ਨੋ ਟੈਂਨਸ਼ਨ,no girlfriend no tension,website: Punjabi.c-o.in,forum: punjabiteacher.co.cc
jatt is offline
Old 02-01-2008, 08:46 PM   #9 (permalink)
All of u are suggesting repartition / format ..
Isnt there any chkdsk type utility etc which can give me more details on what may be wrong ??
Coz i dont wanna format right now .. Difficult to backup 250GB data ..
If i can do that, then i can easily send it for replacement as WD picks it up from home.
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 02-01-2008, 09:19 PM   #10 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
^^there is diagnostic tool for WD which chks for HDD problems, go to the site and choose ur model
zyberboy is offline
Old 02-01-2008, 10:45 PM   #11 (permalink)
Once there is some bad sector, the first thing to do is to back up and get it replaced. Temp solutions may work temporarily but the bad sectors are going to increase over time.
V.Prem Kumar
janitha is offline
Old 03-01-2008, 12:39 AM   #12 (permalink)
@zyberboy i tried the utility .. its useless .. just shows u about details of HDD and partition etc .
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Old 03-01-2008, 12:56 AM   #13 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
^^lol....der is test within that program, i hav done the same.
zyberboy is offline
Old 03-01-2008, 10:30 AM   #14 (permalink)
ummm i got the data lifeguard tools .. i cdnt find any test ..
Asus A8N-E
Nvidia XFX 7600GT
17" LCD Viewsonic
CyCo is offline
Why hard disk drive as removable drive? Sheik Rasheed K Hardware Q&A 6 25-03-2007 10:01 AM
hard drive help niraj trehan Hardware Q&A 17 13-03-2007 06:57 PM
Hard Drive toooo hard for 815 Sonu Yadav QnA (read only) 20 16-06-2005 03:55 PM
Hard Drive! Optical or Magnetic Based Drive Stitch QnA (read only) 1 30-05-2005 11:14 PM
hard drive imported_renault QnA (read only) 20 23-05-2005 01:32 PM
