Old 01-01-2008, 01:30 PM   #1 (permalink)
=--=l33t=--=
ring_wraith's Avatar
Default UPS or PSU causing problem?
Hi.
I have a PTX UPS and a Zebby PSU 400W. I have a strange problem....
Whenever there is a power cut my PC switches off instantly like I dont even have a UPS The funny thing is that it sometimes stays on , but most of the time goes off.
So i was wondering is it coz my UPS is really old? Like 2-3 years old? I have never really given it for servicing or anything like that...
However I was thinking that it could be because of my stock PSU. I read that some PSUs are too weak to even stay onin the brief interval between the cutting of the power and the UPS activating....
So what is causing my problem according to you?
ring_wraith is offline
Old 01-01-2008, 01:37 PM   #2 (permalink)
Default Re: UPS or PSU causing problem?
Change the battery if you haven't done it before in 2-3 years. Get the circuits checked if the power supply is not stable(ie it fluctuates regularly)
ThinkFree is offline
Old 01-01-2008, 01:39 PM   #3 (permalink)
a_g = JPKN
s18000rpm's Avatar
UPS.
today my PC shut down when there was a power cut, even though i have UPS, just 1month old(APC ES500).
could be coz of weak battery, i ran the PC on UPS for 5-10mins yestrday.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 01-01-2008, 01:43 PM   #4 (permalink)
Even a brand new UPS would not work well unless you would keep it fully charged
Old 01-01-2008, 01:55 PM   #5 (permalink)
a_g = JPKN
s18000rpm's Avatar
dunno whether it was fully charged at that time, but doesnt a UPS charge when on mains?
yesterday after tat 5-10min usgage on UPS, i used the PC for well over 3hours (when pwr came), isnt that enuf for the battery to get re-charged?
Old 01-01-2008, 01:59 PM   #6 (permalink)
If that's the case, some problem is definitely there in the UPS, may be either in battery or in any other part. It would surely be in warranty period , so contact service center
Old 01-01-2008, 02:01 PM   #7 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
This is definitely due to UPS, due to delay in its changeover time...its better to service such UPS becoz its the problem with circuitry. It can be also due to connecting heavy load than the rated one.
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 01-01-2008, 02:04 PM   #8 (permalink)
=--=l33t=--=
zyberboy, how do i find out the rated load?
Old 01-01-2008, 02:07 PM   #9 (permalink)
a_g = JPKN
s18000rpm's Avatar
will test it again (manually), if it fails again, i'll get it replaced.
btw do all APC UPS take like 10secs to turn ON? it even makes some noise, Instruction manual says the UPS runs a "test ". but everytime?
Old 01-01-2008, 02:11 PM   #10 (permalink)
=--=l33t=--=
^^ thanks for hijacking my thread man
Old 01-01-2008, 02:25 PM   #11 (permalink)
a_g = JPKN
s18000rpm's Avatar
c'mon man, three guys already answered you.
Old 01-01-2008, 02:45 PM   #12 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
First u will need to find the total power for ur compu using online power supply calculator such as this http://www.extreme.outervision.com/p...ulatorlite.jsp
If u have a 600VA ups u can connect a total load of 360w (if its a good brand), if its 800va u can go 480W.
u can connect upto a 400~450W load in 600VA ups but it will create problems..like overheating ups,or random shutdown as u faced.
zyberboy is offline
Old 01-01-2008, 05:48 PM   #13 (permalink)
=--=l33t=--=
Ummm... i dunno which I have..... man I am such a noob when it comes to UPSs..... Its not mentioned on the back either....
My power req is kinda above 360W... I've never experienced a overheating UPS, so i guess my UPS is 600VA, and the random shutdowns are caused by my underpowered UPS?
Old 01-01-2008, 06:03 PM   #14 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
if u r getting proper backup with this ups then its the problem with circuitry otherwise its due to weak battery.
zyberboy is offline
PSU causing Problems? ring_wraith Hardware Q&A 7 06-12-2007 11:08 AM
WINLOGON.EXE Causing Problem sainit Software Q&A 4 07-06-2007 07:40 PM
Window Defender Causing Problem sainit Software Q&A 5 26-01-2007 08:23 AM
One unknown folder causing problem H.Lalnunmawia Software Q&A 1 27-12-2006 09:14 AM
WMP causing problems vysakh QnA (read only) 4 15-03-2005 10:05 AM
