Old 31-12-2007, 09:10 PM   #1 (permalink)
pratik03's Avatar
Default Good SMPS needed for XFX 8600GT
Need good SMPS for XFX 8600GT
My configuration is
Pentium D 930, 945G motherboard, one HDD & DVD writer
I have recently Burnt my Zebronics 400W SMPS (after installing graphic card)
if possible also quote Lamingnton road prices
pratik03 is offline
Old 31-12-2007, 09:13 PM   #2 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Default Re: Good SMPS needed for XFX 8600GT
Zebronics 500w pure platinum, price will be around 1.8k
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 31-12-2007, 09:40 PM   #3 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
+1 for zebronics...... good value for money
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 31-12-2007, 09:57 PM   #4 (permalink)
pratik03's Avatar
Post Re: Good SMPS needed for XFX 8600GT
Any other Brand
pratik03 is offline
Old 31-12-2007, 10:01 PM   #5 (permalink)
Anything from the Antec shelf...... Neo power
Sony Vaio CW26FG
Old 31-12-2007, 10:05 PM   #6 (permalink)
pratik03's Avatar
Antec Neo power is too costly
pratik03 is offline
Old 31-12-2007, 10:08 PM   #7 (permalink)
Then stick to zebronics..............
Sony Vaio CW26FG
Old 31-12-2007, 10:08 PM   #8 (permalink)
I use zebronics & its good except that it requires a cabinet which lets you a fan output on the top back of the cabinet, so choose accordingly your cabinet.
ranjan2001 is offline
Old 31-12-2007, 10:34 PM   #9 (permalink)
pratik03's Avatar
I have just seen image of Zebronics 500w Platinum SMPS it has big fan top of case.
http://www.zebronics.net/images/powe...platinum_b.jpg
After mounting SMPS in the case what is the position of fan towards the motherboard or upper side case ?
pratik03 is offline
Old 31-12-2007, 10:39 PM   #10 (permalink)
Both ways possible, but I could not find any zebronics cabinet or any other company which can output air to top so mine is mounted ulta.
Old 31-12-2007, 10:48 PM   #11 (permalink)
pratik03's Avatar
Is that big fan Noisy ?
pratik03 is offline
Old 31-12-2007, 10:52 PM   #12 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
lolz.......the zeb fan shud be under not on the top,the fan blows inward.
And its not noisy
zyberboy is offline
Old 31-12-2007, 11:11 PM   #13 (permalink)
And its not noisy
Its not so noisy but why should it blow inwards since its above the cpu fan where it interfere with the cpu fan flow?
Why would u prefer it inward?
Old 31-12-2007, 11:30 PM   #14 (permalink)
dOm1naTOr's Avatar
It sucks air from inside of cabby and blows out thru rear like most other PSU. It just that the fan is located at bottom of PSU though the direction of airflow is same as others.
Even Platinum 400w is more than enuf for his config. If hes gonna have a gcard, then get 500w platnum for 1.7k.
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 31-12-2007, 11:35 PM   #15 (permalink)
In both the positions it cannot suck the air from within the cabinet.
I don't understand how else you mean to say what u say, can u explain?
Old 31-12-2007, 11:38 PM   #16 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
by inward i meant into the smps, the fan blows such that it cools the heat sink inside smps.
why not it sucks air frm top of the cpu fan...not much interference der.
zyberboy is offline
Old 31-12-2007, 11:40 PM   #17 (permalink)
This is how I have it mounted flowing downwards & I don't thing it should be mounted downwards as it surely disturbs the airflow, but I don't have a choice
Old 31-12-2007, 11:45 PM   #18 (permalink)
dOm1naTOr's Avatar
he he...this cud help
sorry...i didnt have time for corect drawing.[haf xam 2moro]
Mine too is 500w platinum is its sucking air from underside and throwing out from rear.im sure of it.
But somewhere heard that earlier platnum models had inverted fan which worked in opposite dir.
G3: XPS M1530 |
FZ 16.
Old 31-12-2007, 11:45 PM   #19 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
@ranjan2001
in ur case its somewhat closer to the cpu fan,since both fans sucks inside i dont think it will cause any problem for ur cpu fan
zyberboy is offline
Old 31-12-2007, 11:50 PM   #20 (permalink)
I bought this in feb 2007 & in my case it seems the fan is mounted ulta (then it does not suck air) I am sure too it throws air inwards right above the SMPS fan which is not good but I did not have much choice.
Once its outof warranty I will open & mount it ulta so it sucks out the hot air.
Old 31-12-2007, 11:59 PM   #21 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
is it? then it will cause much more heat inside the cabby
zyberboy is offline
Old 01-01-2008, 12:05 AM   #22 (permalink)
dOm1naTOr's Avatar
@ranjan2001
are u sure its ulta?
try placing a very thin plastic film[the one in which digit DVDs come] in fron of the fan nd see if its attracted or repelled. We can't say the correct direction of air by simply placing hand coz there are many other air flow channels due to many other fans close by[cpu, cabby etc].
so the best way is to use film. try it
G3: XPS M1530 |
FZ 16.
Old 01-01-2008, 12:10 AM   #23 (permalink)
Yes its ulta in one of my cabinet I have 2 of them, the other one is rightly installed as u have mentioned.
Old 01-01-2008, 12:22 AM   #24 (permalink)
pratik03's Avatar
Guys thanks for such comprehensive illustrations.
pratik03 is offline
Old 01-01-2008, 12:27 AM   #25 (permalink)
u r most welcome, if u buy zebronics make sure to check the fan mounting.
I like these forums as they help us a lot before we buy anything.
Is this SMPS good enough? harsh bajpai Hardware Q&A 16 06-01-2009 06:33 PM
8600GT or 8600GTS or 8600GT Fatality bajaj151 QnA (read only) 31 12-08-2007 08:38 PM
which cabinet/smps will be good for this config ? myhotdog PC Components / Configurations 8 18-04-2006 11:33 PM
Zebronics 500W SMPS. Is it a good SMPS. Advice needed. Yoda QnA (read only) 4 13-11-2004 11:15 PM
Suggeset a Good Replacement for my SMPS and UPS. Yoda QnA (read only) 2 04-11-2004 05:29 PM
