Old 31-12-2007, 03:38 PM   #1 (permalink)
Its Best only if its open
ankushkool's Avatar
Default HELP pleeeez... ext HDD
i bought a 500GB maxtor basis ext HDD a week ago. de 1st day it worked fine... but after few days it gave some prob... n not its completely not workin.
think there is some prob with de power supply. but when i contacted Segate service they said they will replace it but will not recover de data.
WHAT sud i do? i m soo depressed
ankushkool is offline
Old 31-12-2007, 03:49 PM   #2 (permalink)
TechTin.com
ravi_9793's Avatar
Default Re: HELP pleeeez... ext HDD
first try on other system ..
ravi_9793 is offline
Old 31-12-2007, 04:05 PM   #3 (permalink)
ankushkool's Avatar
tried everythin... it just dosent get de power... even changed de power cable
Old 31-12-2007, 05:03 PM   #4 (permalink)
TechTin.com
ravi_9793's Avatar
than must be problem with the hard disk itself.
Get it repleced .
Old 31-12-2007, 05:27 PM   #5 (permalink)
Wire muncher!
infra_red_dude's Avatar
Check if the casing requires a dual head usb connector for sufficient power.
infra_red_dude is offline
SEVERE PROBLEM urgent help pleeeez ionicsachin QnA (read only) 4 09-07-2005 10:29 PM
