Old 31-12-2007, 12:11 PM   #1 (permalink)
The Demun
Sinja's Avatar
Default Need Advice on Best budjet Cabinet for pc running 22/7 without ac
hello friends
im using an old cabinet for ma pc with 2 fans and 1 onf them does not work properly. im planing on buying a new cabinet.
my hardware
1gb ram ( upgrading to 2 gb ram)
intem 915 mobo
-intel 3.0 Ghz Pentium processor
-- gettting xfx 8600GT
my pc will run 22/7 running games and applications. wat sort of cabinet should i use can u suggest budjet cabinet.
Ragnarok is a way of life ^_^
Join the wonderfully addictive world of ragnarok be a Rag addict the ultimate addiction in MMORPG
Sinja is offline
Old 31-12-2007, 12:25 PM   #2 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
Default Re: Need Advice on Best budjet Cabinet for pc running 22/7 without ac
go for zebronics peace cabinet with one side ,top and 120mm rear led fans. Cost around 1800Rs without smps
http://www.zebronics.net/gamingcabin.asp
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 31-12-2007, 12:28 PM   #3 (permalink)
Google Bot
Pathik's Avatar
Also upgrade ur mobo+proccy if u can.. they r huge bottlenecks..
Pathik is offline
Advice on new power supply and Cabinet mukherjee Hardware Q&A 6 29-07-2007 10:42 PM
need help regarding Cabinet nd4spd Hardware Q&A 11 02-04-2006 07:58 PM
Cabinet help please!! jetboy Hardware Q&A 16 20-11-2005 09:06 AM
GFX,DVD,cabinet and PSU : Help me plz... Monster_AMD QnA (read only) 5 10-06-2005 11:56 AM
which of the following Cabinet u like??? [flAsh] Software Q&A 17 28-05-2005 07:28 AM
