Re: hlp BSOD
You haven't specified your OS. I am assuming Windows XP.
-First uninstall Intel graphics drivers from add remove programs.
- Then reboot using the windows cd. You may have to change the boot sequnce in bios to boot from your cdrom. To do that press f2, f12 or del, whatever is shown at the bottom of screen, when the system starts up, before windows starts. Now find an option like 'First boot device' or 'boot device priority' and here change the First boot device to your cdrom. Save and exit setup.
- Upon restarting, press any key to boot from cd when the message shows up. When first setup screen shows up, press R to enter recovery console.
- After choosing your windows installation and giving the Administrator password, run these commands:
chkdsk /p <drive>
replace drive with actual letter of the partition on which window is installed, which in most cases is C:.
so in that case the command will be : chkdsk /p c:
- Reboot and reinstall the drivers. Chances are you wont face the problem again.
If it happens again then repeat the above steps, just replace the command with
chkdsk /p /r <drive letter>.
Try this out and post again.
Dell Inspiron 1525 - C2D 2 Ghz, 3GB, 250GB, X3100 :)
Samsung Omnia Pro B7610 with Stock WM 6.1 ROM
Blog: http://www.sumitbhardwaj.co.in/blog
