Old 30-12-2007, 03:16 PM   #1 (permalink)
Default RAM not specified in Asus P5NSli QVL
Hi Guys,
I got myself a P5NSLI mobo and 2x1 DDR2 667 Transcend RAM to go with it. Even though Transcend is specified in the QVL for P5NSLI, the chip code of the RAM that i got is not present in the QVL. I have not opened my mobo and RAM pack. Should I go ahead and assemble or should I change the RAM modules? Please help...
Thanks in advance,
Manoj
manoj7777777 is offline
Old 30-12-2007, 07:45 PM   #2 (permalink)
Default Re: RAM not specified in Asus P5NSli QVL
Hi ppl,
I finally went ahead and assembled the sys.. the specs are
Mobo : Asus P5NSLI (nVidia 570 SLI chipset)
Cpu : Core 2 Duo E4500 2.2 Ghz
2x1 GB Transcend 667 Mhz DDR2 RAM
XFX 8600 GT 256 MB
250 GB SATA
Zebronics Bijli cabby
Once we started the system.. nothing happened and no beeps were heard. the keyboard LED flashed just once and then stopped responding. We had a doubt with the CPU-Mobo compatability and found that E4500 was supported by the Mobo from BIOS ver 1401. the problem is Am not able to find the stock BIOS version. Asus tech support site seems to be ineffective as well.. any suggestions or workarounds ???
Old 30-12-2007, 08:28 PM   #3 (permalink)
Alter Bridge=GOD
nish_higher's Avatar
stock bios is in the CD that comes with ur motherboard.and asus support site has all bios released.
Apple Macbook Pro 17
nish_higher is offline
Old 31-12-2007, 10:00 AM   #4 (permalink)
darklord's Avatar
the current bios of the board can be seen on the actual bios chip onthe motherboard.A small sticker is pasted over the chip with existing bios version.
Also if possible, change that board Nforce5 series chipsets were never meant for Core CPUs.
Here are your options -
1] Asus P5N-E SLI (650i SLI)
2] XFX/Galaxy 650i Ultra (650i Ultra, Nvidia reference design)
3] Abit IP35-E ( Intel p35)
4] Biostar P35 ( Intel P35)
5] Gigabyte G33 (Intel G33, onboard Video)
6] Gigabyte G31 (Intel G31, onboard video)
I guess these are sufficient options, these options are with different Prices. I am not aware of your budget.
darklord is offline
Old 31-12-2007, 12:24 PM   #5 (permalink)
Alter Bridge=GOD
^ everything except p5n-e-sli
Old 01-01-2008, 01:34 PM   #6 (permalink)
darklord's Avatar
whats wrong with P5N-E SLI ?
darklord is offline
Asus G1s faraaz Mobiles and Tablets 5 24-11-2007 07:37 PM
ASUS 5900Ultra or XFX 5900 ultra or ASUS 6600 or XFX 6600 ?? rachitboom2 QnA (read only) 1 07-03-2005 02:32 PM
ASUS 5900Ultra or XFX 5900 ultra or ASUS 6600 or XFX 6600!!! rachitboom2 QnA (read only) 1 06-03-2005 04:05 PM
