Old 29-12-2007, 09:32 PM   #1 (permalink)
Default Help Needed Please!
I have panasonic tv TC 2195. My problem is when i connect xbox(normal) or sony dvd player i do not get color in my video.Sound is proper. Find my tv's connector picture as an attachment. I have two slots of two pin each..one white for audio n one yellow for video.
Appreciate your concern to read my problem.Hoping reply.
thanks
What doesn't destroy me, makes me stronger.
jamifahad is offline
Old 31-12-2007, 07:53 PM   #2 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
Default Re: Help Needed Please!
probably because ur tv is PAL and ur game console is displaying NTSC or vice versa.
find out the type of input ur tv is (PAL or NTSC) and set that as output video type in console.
Rollercoaster is offline
Old 31-12-2007, 11:02 PM   #3 (permalink)
OR change the type in the tv itself .(PAL or NTSC)
sagargv is offline
Old 31-12-2007, 11:11 PM   #4 (permalink)
anand1's Avatar
If after all the above said settings the problem prevails then try to change your connecting wires this may also be due to faulty cable you are using for connecting it.
Technology On The Fly
anand1 is offline
Old 31-12-2007, 11:15 PM   #5 (permalink)
damn busy...
utsav's Avatar
Cable fault wil not cause this problem
MSI GX660 with ATI 5870 ultimate gaming lappy
Dell Studio 15(1555)
1TB+1.5TB external|N86|ZTE Blade|5230|E63|EP-630|Soundmagic PL50|Sennheiser CXL 400|Meelec M11P+
www.techjunkiez.com
utsav is offline
Old 01-01-2008, 03:56 PM   #6 (permalink)
well my tv does support pal as well as ntsc. cables are working fine because the same cable i use with my other tv where everything works fine
i have ps1 which i connect to same panasonic tv using a NTSC-PAL connector for playstation.Find picture of it in attachment.Through this device im able to get color in my video.
Old 09-01-2008, 11:23 AM   #7 (permalink)
it means that somehow ur tv is not able to switch between pal/ntsc or it can only be done manually.
Old 09-01-2008, 01:30 PM   #8 (permalink)
hmmm...well i think you right roller. my T.V doesn't support pal/ntsc switch.nyway thanks alot you guyz..if u come across anything useful regarding this lemme know.
Help needed. Things needed to connect SATA HDD to... prashantmaxsteel Hardware Q&A 3 21-11-2007 12:26 PM
needed 2 buy a good camera????? help needed.. The Day Walker! Cameras and camcorders 5 02-07-2005 04:43 PM
