| Forum |
#1 (permalink) |
i am able to write cd properly with no probs. i use two dvd-rw 1. LiteON LH-20a1p 2. sony dvdrw awg170a both of them are not able to write DVD and burn process fails. what's wrong they are not even an year old, though it's been 1 month I hav'nt used them much and now when i need them they are not working. this is definitely a hardware problem. please help using winxp sp2 c2d e6300 processor g965 mobo ASUS 1gb ram @667MHz Last edited by Gaurav; 27-12-2007 at 09:58 PM. |
#2 (permalink) | |
is NOT a PC/Mac
#3 (permalink) | |
and the problem is this that the burn process simply fails. |
#4 (permalink) |
Wire muncher!
1) Check the data cords (IDE/SATA cables), replace if necessary and test.
2) Check power connectors 3) Use a different software 4) Boot into a second OS, if you haf OR Use a Linux Live CD and try burning in from there 5) Try changing the media 6) Check in device manager for settings related to IDE/SATA Controller and DVD RW Drives for any problems/changes.
"The true measure of a man is how he treats someone who can do him absolutely no good." http://phoenix-ani.blogspot.com |
#5 (permalink) |
The Devil's Advocate
or u cud try another writing softy; try the default windows writer
"The problem that shows up with the three red lights on the console is a complex interaction with some very complex parts.” - Robbie Bach http://beingmanan.com twitter: manan | Last.FM: manan |
#6 (permalink) |
windows burning software does'nt work either.
checked power connectors and everything i could, even updated the firmware. did'nt helped. what's wrong... even if i purchase a new one what's the guarantee that the new one won't have the same prob,. |
#7 (permalink) |
Wire muncher!
^^^ none of the software works? Then try booting into a linux live CD/DVD and try burning from there. It seems the imapi service in windows is not loading or there is some problem with the burning engine. Check control panel > admin tools > services and check if there is any error when launching the IMAPI service.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Cannot write... | soumya | QnA (read only) | 5 | 27-06-2007 08:37 PM |
| cannot write more than 32X | gau_pppu | Hardware Q&A | 4 | 08-12-2006 02:25 PM |
| any way to write encarta dvd to cds. | harsh bajpai | QnA (read only) | 6 | 08-01-2006 11:33 AM |
| unable the write cds at 48x | manmay | QnA (read only) | 8 | 20-12-2005 11:10 PM |
| HOW TO WRITE A CD | mandar5 | QnA (read only) | 18 | 17-08-2005 07:50 PM |
