| Forum |
#1 (permalink) |
How can I fix the problem ? What could be the reason ? Vishnu |
#4 (permalink) |
Have u installed or uninstalled any of the software or the Hardware before the problem arised. If so then go for system restore at Safe Mode. This generally happens due some conflicts.
Technology On The Fly |
#7 (permalink) |
U should scan if ur original windows files r intact
ur pc works in safe mode , so start command prompt and type sfc /scannow u will need windows cd to verfiy the integrity of ur system files |
#8 (permalink) |
Start Your computer with "Windows Advanced Options" , Select Safe mode- Once you reach upto Login screen or Logon Phase- Press - ALT+CTRL+DEL - Once you get Tast manager Windows - Click on File- New task - Type- Msconfig- GENERAL TAB- Select- Selective Startup- Uncheck - Load Startup items, SERVICES TAB- Check - Hide all Microsoft Services- Click on Disable all- Click on Apply, Click on Ok, Restart the computer, See if you are able to boot up properly, if yes then First Enable all the services, and restart check for the problem , if Not Select Startup items- 2-3 at the same time and check.!! See it will work!!!
speedrider - The ultimate |
#9 (permalink) |
Fast 'N' Furious
fix your hard disk by runnig
chkdsk /f /r
ToPsPeEeD = FaSt BuT StEaDy AMD Radeon HD 6850 OverClocked to 1 Ghz !!! Blog : http://topgeartopspeed.wordpress.com/ ---------------------------------------------------- Never buy viewsonic products : http://tinyurl.com/ykwx4oa |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Help me... Getting startup problem | jyoti.mallick02 | Software Q&A | 7 | 08-12-2007 07:42 PM |
| System Startup Problem............ | satyamy | QnA (read only) | 3 | 13-02-2007 03:10 PM |
| startup ok but shutdown have problem | reddragon | Hardware Q&A | 1 | 02-07-2006 09:37 AM |
| startup problem | sujeet2555 | QnA (read only) | 1 | 28-07-2005 05:18 PM |
