| Forum |
#1 (permalink) |
i have a problem. when i write a dvd, it gets on till 5-6%(in Nero). then it suddenly says "Problem in Writing". it displays a message " internal error : RAM error reading MATISTHUTA UJ850(my ROM's company)". what should i infer from it. plz comment... |
#3 (permalink) |
Romeo + Lucifer = ME
If cleaning doesnt work then run some ram test n if u find them faulty then get new modules
Sony Vaio CW26FG Nokia E 63 + Iphone 3GS Nikon D3000 + 50mm f/1.8 + 70-300mm Lens |
#4 (permalink) |
HELP AND SUPPORT
Change the size of the virtual memory paging file, follow these steps:
1.Click Start, click Control Panel, click Performance and Maintenance, and then click System. 2.Click the Advanced tab, and then under Performance, click Settings . 3.Click the Advanced tab, and then under Virtual memory, click Change. 4.Under Drive [Volume Label], click the drive that contains the paging file that you want to change. 5.Under Paging file size for selected drive, click Custom size, type a new paging file size in megabytes (MB) in the Initial size (MB), or Maximum size (MB) box, click Set, and then click OK three times. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| got a new dvd writer Samsung Super WriteMaster 18x DVD Writer | xbonez | Hardware Q&A | 7 | 14-08-2007 02:10 PM |
| Writing DVD RWs... | shyamno | Hardware Q&A | 13 | 02-05-2007 12:53 PM |
| Writing not done | kumarn_2004 | QnA (read only) | 2 | 30-03-2007 03:01 PM |
| USB writing pad 4 PC | cooldude | Hardware Q&A | 1 | 18-10-2006 10:58 AM |
| DVD Writer not writing DVDs, Please help | Anurag A | Hardware Q&A | 2 | 01-09-2006 06:29 PM |
