| Forum |
#1 (permalink) |
macaddict
any suggestions? |
#2 (permalink) |
CG Artist
damn.I have the same problem.And i can see many people with this problem.But no solution.
And plz tell your config and software u have on your system. |
#3 (permalink) | |
macaddict
#5 (permalink) | |
macaddict
#6 (permalink) | |
CG Artist
#7 (permalink) |
Please post your Pc specifications:-
Computer freezing cannot be caused by a bad psu because bad psu will lead to turn off the LED lights on your cabinet and turn off your computer abnormally. This problem can be caused by 2 issues. 1.Some driver problem.Bad drivers passing through memory can cause this. 2. bad ram Ram can always be tested by a utility called memtest.Just google it and download .Burn the iso on cd and bot through the cd.Then start memory test. Run it for 3-4 hours .See if there any errors .If there is one or more error then its time to replace your ram. If its a driver problem then install a fresh copy of windows.Install your softwares one by one .Wait for some time and see if it freezes and then install another software and then wait for some time and so on. You have bought a new dvd writer .just detach it and see it might be the culprit.Recent hardware changes can also cause it. Another way of checking ba driver is just log onto safe mode and see if your computer freezes.If it freezes then definitely there is a hardware problem otherwise it is driver problem. |
#8 (permalink) | |
macaddict
dr.gauravsuneja@yahoo.com |
#9 (permalink) |
die blizzard die! D3?
^^gaurav_indian he was asking about CPU temps not your room temp.
BTW which windows you have gauravsuneja?and please don't use dear!!it sounds so gayish(I hate to say this but...) how to check?install speedfan and then tell us all the stats it shows.Google for speedfan.
Stealing your women and horses since 1843. |
#10 (permalink) | |
macaddict
#11 (permalink) | |
CG Artist
I have checked my ram through Memtest and other programs and its fine.HDD is also fine.I have Autodesk Maya installed in my system.And ever since i have installed it,it has caused some problems.I have formatted my drive and installed windows xp(original) thousand times.
Last edited by gaurav_indian; 25-12-2007 at 09:51 PM. Reason: Automerged Doublepost |
#12 (permalink) | |
@gaurav_indian:get speedfan and then post all your temps. antibiotic cabinet se kuch nahi hota dimag bhi lagana padta hai.
#13 (permalink) | |
CG Artist
#14 (permalink) | |
macaddict
lets come on yahoo conference i think it wil be better dr.gauravsuneja@yahoo.com Last edited by gauravsuneja; 25-12-2007 at 10:00 PM. Reason: Automerged Doublepost |
#15 (permalink) |
^^no please talk here only so that others are also benefited.
to both of you either get SPEEDFAN or CORE TEMPcore temp is known for working very good on c2d's but speedfan gives you all the reading unlike coretemp which gives you just cpu temp readings.And yes they don't create problems!
#18 (permalink) |
Rising ApocalypsE
Guys the temp. that u mentioned is nothing for ur system to kill ur brain.
Just rip apart every single thing in your system and reinstall every component after cleaning it and make sure to check every connection twice or thrice if required. Install a fresh copy of your operating system with all updates included and also install latest drivers from their respective hardware sites. Do check this and see if the problem persists again.
AMD Athlon 3200+,MSI RS482M4-ILD,Kingston KVR 512MB 400,Gainward 6800GS 256MB,250GB WD Caviar,Cooler Master 430Watts. |
#20 (permalink) |
macaddict
if the ubuntu installation too freezes it means some hardware problem? but with safe mode it worked well.(windows xp).i am confused again.what to do?memtest no problem hdd temp 25degress
#22 (permalink) |
@ gauravsuneja
Your motherboard capacitors may be the culprit.....it's common with old motherboards.Inspect the capacitors on your board(if you know a capacitor from a coil) for bulginess or cracks on the top.
Let there be music..... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Does your IE6/7 freezes ? | Faun | Chit-Chat | 29 | 08-12-2007 10:31 PM |
| Computer freezes!!! | sudhix | Software Q&A | 2 | 04-01-2007 11:22 PM |
| computer freezes when I start surfing | Gaurav | Software Q&A | 12 | 06-01-2006 10:14 PM |
| Pc Freezes! | vij26 | Software Q&A | 6 | 21-03-2005 11:23 PM |
