Old 25-12-2007, 09:19 AM   #1 (permalink)
Default Changing CPU
Hi guys ,
I just wanted to know wid the release of intel's quad core CPU at a cost as low as 11000 that can i just change the dual core processor on my motherboard with a quad core one...without having to change my motherboard...
utkarshsingh_91 is offline
Old 25-12-2007, 09:25 AM   #2 (permalink)
Commander in Chief
QwertyManiac's Avatar
Default Re: Changing CPU
Give your motherboard details as well.
Most 945/946 series and 965 ones do support Quad CPUs. Below these models, none do.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 25-12-2007, 11:08 AM   #3 (permalink)
actually i m buying a pc from dell....and they dont tell u the mboard model on net...
so i cant telll..
but both dual core and quad core are pinless processors so y cant the older ones which support dual core cant support quad cores
Old 26-12-2007, 02:14 PM   #4 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
Download CPU-Z and check your motherboard
keith_j_snyder2 is offline
Old 26-12-2007, 07:54 PM   #5 (permalink)
Fast 'N' Furious
topgear's Avatar
Go for those computers of dell which has c2d e4300 or above processors bundled with them.
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 27-12-2007, 01:43 PM   #6 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
I don think any branded pc wil have a dual core proccy mounted on a quad core supporting mobo
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Changing IST from +5.30 to +6.00 ╬Switch╬ Chit-Chat 6 03-09-2007 11:08 PM
changing name vineeth.gk QnA (read only) 5 28-07-2007 12:22 AM
changing ip!!! prinz QnA (read only) 6 03-07-2007 12:48 PM
Changing The Order... BBThumbHealer QnA (read only) 3 08-05-2007 01:35 PM
Changing Faces NikhilVerma Tutorials 13 14-06-2005 12:14 AM
