Old 24-12-2007, 10:10 PM   #1 (permalink)
User Name's Avatar
Default Is bios upgrade must?
Is bios upgrade neccessary to do?
User Name is offline
Old 24-12-2007, 11:35 PM   #2 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Default Re: Is bios upgrade must?
Upgrade your BIOS only when u need it, it doesnt speed up the system but sometimes it adds some more features if available in the update!
Also make sure that you have proper UPS backup. There should be no power fluctuation in the flashing process otherwise you'll end up into a dead mobo.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 25-12-2007, 03:08 AM   #3 (permalink)
Romeo + Lucifer = ME
codename_romeo's Avatar
^^^^ +1 for that
Sony Vaio CW26FG
Nokia E 63 + Iphone 3GS
codename_romeo is offline
Old 25-12-2007, 10:15 PM   #4 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Only PC Gamers generally do a BIOS upgrade if needed
rakeshishere is offline
Old 25-12-2007, 10:17 PM   #5 (permalink)
die blizzard die! D3?
The_Devil_Himself's Avatar
^^whats that for a condition?
NEVER update your mobo BIOS unless it solves some issue that particularly concerns you.NEVER.
Stealing your women and horses since 1843.
The_Devil_Himself is offline
hoe to upgrade BIOS ? bharatesh Hardware Q&A 2 22-01-2007 12:52 AM
Upgrade Bios freezer QnA (read only) 1 16-11-2006 02:47 PM
Upgrade BIOS codename_romeo Hardware Q&A 8 12-11-2006 06:41 PM
Plz Help me- I Want Upgrade My BIOS rohtak2001 QnA (read only) 5 19-06-2005 09:42 AM
help me to upgrade my bios jitu_mania QnA (read only) 1 16-01-2005 04:19 PM
