23-12-2007, 07:24 PM
Alter Bridge=GOD
Asus P5k-c or XFX 680i LT?
i am buying a new motherboard for this config-
Asus p5n e sli
Intel q6600
4gb kingston ram
xfx 8600gts 356mb
wd 160,wd 250,wd 250--sata IIs and a 250gb pata hard drive
a dvd writer (a vintage one)
i want to change my mobo since i m fedup with stability issues of p5ne sli.
can u suggest me which of the two mb's is good?my budget is below 10k.can u suggest me some other board?preferabely SLI ?
Apple Macbook Pro 17 :cool:
23-12-2007, 09:00 PM
ToTheBeatOfUrHeart
Re: Asus P5k-c or XFX 680i LT?
What stability problems are u having??
The P5N-E SLI has problems setting FSB between 400-450Mhz,u can go higher and lower but not between 400-450Mhz.
Have u updated your to 0703 Bios,not beta.
24-12-2007, 09:17 AM
Alter Bridge=GOD
well i have only performed that AI overclocking-20%
my bios is 0703
the problems are simple--the day i bought it i was not able to install vista.i changed my PSU as the guys on toms hardware said.still no result.then somehow vista loaded.i think i changed Pnp os settings for that.
and i m also facing problems with 8600GTS in sli.my pc freezes.
yesterday vista froze and since then even new installations are not working.i've checked every hardware i have on my frnd's pc but everything is fine.
now i m thinking of sending this board to Asus and if there's something wrong they winn sort it out.and later i will sell it.so i need a new board.can u suggest me one?
24-12-2007, 03:09 PM
Alter Bridge=GOD
i m gonna order a new board tomorrow and i m thinking of P5k-C since it supports DDR3..any suggestions plz??
24-12-2007, 03:21 PM
| Game Artist |
U might want to consider ABit IP35 Pro, very good for overclocking!!!
<< Passion Rules The Game >>
24-12-2007, 05:11 PM
ToTheBeatOfUrHeart
I see u have 8600GTS SLI and i don't think P5KC has SLI support so your stuck with buying XFX 680i LT SLI.
Now even this motherboard had stability issues but have been solved with bios updates.
If u plan to get this mobo then do not get old stock.Go to rashi and tell them to arrange one for u so that u don't get an old stock but a new one with the new bios.
24-12-2007, 07:47 PM
Alter Bridge=GOD
no i really dont have SLI yet..the card i paired was my friend's..i was planning to get another one when i found this freeze problem.i tried pairing his card with mine on his pc and it worked (he has p5n32e sli).
24-12-2007, 08:13 PM
ToTheBeatOfUrHeart
It seems that you got a bad board.There are literally tons of good mobos out there but the question is which one's available easily.I suggest you look for a good MSI motherboard.
And this forum has already seen one member having trouble with ASUS customer support in India(they are bada$$es)they don't give a damn about customers.
I literally stop buying stuff which does not deliver the goods in performance after market support.
If though you have a badge on it that says 3 year rashi warranty then you might get it easily replaced.
I don't know much about abit but XFX will be easily available because of rashi.
One thing though once you get the mobo do as much stress testing you can to check its stability,if you find a problem ping the place from where you bought the mobo and get it replaced quickly with a non defective one.
24-12-2007, 08:47 PM
Alter Bridge=GOD
well i already have Asus A8N SLi Deluxe and i have got it replaced once within a week.there was some problem with its power and it was a great response from ASUS.
Also u r right abt MSI and i m also looking for MSI P35 Platinum Combo.one thing i saw was Abit iP35 pro got so good reviews and maybe i can arrange one but it will take time
25-12-2007, 01:05 PM
Alter Bridge=GOD
yet another thing--whenever i try to increase my FSB to 1333 and reboot my pc freezes at the ASUS post check and when i restart i get old stock settings back
25-12-2007, 03:09 PM
ToTheBeatOfUrHeart
Get the mobo changed its bad and probably defective.
25-12-2007, 05:21 PM
Alter Bridge=GOD
i ordered 680i lt along with another 8600GTS  and i m sending this board for replacement and later selling it.
25-12-2007, 05:35 PM
ToTheBeatOfUrHeart
Do post your 3DMark06 score with the 8600GTS SLI.
26-12-2007, 12:15 PM
Rising ApocalypsE
Get an X38 rather than 680i or just wait for 780i or 780i LT or ASUS P5N32-E SLI (680i) but a great moherboard.
26-12-2007, 01:56 PM
Alter Bridge=GOD
well 780i is too costly and i cant wait coz i got some work to do.thats the reason i m getting a new board otherwise i'd have got this board repaired.also almost every P35 board does not support SLi but supports crossfire.since i m buying another gfx card it will be a problem.also the thing is i don't have to pay anything as i m selling asus crosshair..thanks for the suggestion.
