Old 23-12-2007, 03:54 PM   #1 (permalink)
Smile Need buying advice
Hi frnds,
I am looking forward to buy the following. Could you please give the quotations for each and which company shd i go 4?? I reside in Mumbai.. In case u feel like givng my ny additional advice plz continue..
1. Planning to get Xbox 360 Elite.. Ny views on it.. compared to PS3
2. 22'' Samsung 226BW LCD..
3. 300 GB Portable HDD.. Let me knw which brand shoud i go 4..
4. 2 GB RAM ..
5. Plannin to get Windows Vista.. I already hv da serialkey n iso of
it frm net. Altgh Im not very sure wat wud b da end result wen i log on
da net.. Is thr a way 2 crack it ??
Please let me know from where do I get these items.. I know we get in
Laminton Rd but ny specific shop..
Thanks.. hope 2 hear frm u
bruce_wayne_16 is offline
Old 25-12-2007, 11:25 PM   #2 (permalink)
Default Re: Need buying advice
lol.. no reply yet..
Common guys.. help me out yaar
Old 26-12-2007, 11:49 AM   #3 (permalink)
Google Bot
Pathik's Avatar
1. Good choice.
2. Go for 22" Dell displays.. Not much idea about it thoubh.
3. Go for a 250gb laptop hdd + transcend casing for 800 bucks.
4. 2 gb ddr2 800mhz ram.
5. Google..
Pathik is offline
Old 26-12-2007, 11:58 AM   #4 (permalink)
Rising ApocalypsE
keith_j_snyder2's Avatar
U can't compare PS3 with X-360. If ur budget allows then go for PS3, though it doesn't have a huge library as the PS2 and upto some extent X360.
But PS3 is the future of gaming. Besides its something more than a gaming device. Check google about its other uses!
I m damm sure this buy won't be regretted!
keith_j_snyder2 is offline
Old 26-12-2007, 07:30 PM   #5 (permalink)
Originally Posted by bruce_wayne_16
Hi frnds,
4. 2 GB RAM ..
no crack discussion allowed..
1.. i would prefer xbox 360 as it is very good at present but ps3 has good future..
2.. dont know
3.. i prefer 500 gb western digital basic one..(it has two or three versions i think)
4.. 2gb ram what ram? ddr or ddr2?.. why do u need it . imean if u are buying xbox 360 why do u need 2 gb of ram?
adithya_s is offline
Old 27-12-2007, 11:20 AM   #6 (permalink)
2 gb ddr2 RAM.. heard of CORSAIR brand 2...
well i want 2 GB RAM to run Vista on my machine n other applications...
Old 27-12-2007, 11:27 AM   #7 (permalink)
AJJU
azzu's Avatar
^ well if ur novice in Os then ill suggest u to stay with XP...
and get a ps3 ITS THE FUTURE
I love and Live to Design
azzu is offline
Advice on buying digital cameras vishalp007 Cameras and camcorders 8 27-09-2006 11:55 AM
Buying a new 17" LCD monitor...need advice magneto_ms Hardware Q&A 33 25-08-2006 12:59 PM
Buying a graphics card..need advice zuala77 Graphic cards 4 10-02-2006 09:59 PM
Buying AMD 64 bit. Advice needed rajendra99 CPU / Motherboards 15 29-08-2004 09:53 AM
